HELP PLEASE! 5dr s-techs and df210???
Hey guys I got a 2010 5dr lb . Just bought some ROTA GT3 16x7 +40 with 195/50/16 tires. I been doing some research into springs for my car too. There are s-techs with a 1.9" drop and df210 with a 1.6/1.8" drop. Then I search up to find there are 5dr tein s-techs with a 2.1/2.3" drop and df210 with a 1.6/2.1" drop. Can both springs be used or only the 5dr ones since I have a 5dr? Would I have any rubbing issues with any of these springs with the wheel/tire setup I have. Anyone got any pics with the 5dr springs??
Thanks guys!! |
DAT'S RIGHT I GOTz 2
um.....you drive a 5dr but your info says 3dr?
My bad didn't even realize, I'll change that now if I can!
Anyone??????
dunno with your rims i'll go for a lesser drop (df210s in your case). you have a bigger chance to rub in the front if you go lower.
the springs are probably the same, the only difference is that our 5dr are alittle heavier than the 3dr so it will lower a little more. did they have different part numbers?
#7 | |
toyota
Same part number same price for the s-tech's. The df210 I think are same part number but are about $80 more expensive
If there the same number then the drop difference will be because of the weight of the
5dr to 3dr |
Your car looks awesome, I only found one pic on the forums. Could you upload some more if you have any please?
toyota
