![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Limited Slip
Is there any way to change to a limited slip differential with a Yaris 5 spd ?
Yes. www.microimageonline.com sells LSDs.
There is TRD, which you must import (expensive side) and KAAZ, which I run in my car (less expensive side). I am very happy with the one in my car.
![]() ![]() Drives: yaris Join Date: Nov 2008
Whats difference LSd 1 way & 1,5 way?
multimakmurperformance.com |
1-way only works during acceleration, 1.5 way works also with deceleration.
I THINK.
Drives: yw calls me douche and racist. Join Date: Aug 2007
It only works half in deceleration. Hence 1.5.
I know on my chevy pickup the posi rear is a life saver in the snow.
Would it be a safe bet that the TRD LSD for the Yaris would be a big advantage in the snow ? |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
It would be, but being a FWD car, the Yaris should get around okay in the snow, anyway. Good snow tires would probably be a better investment. Without them, even with an LSD... you'd just be spinning two tires instead of one. (which is arguably more dangerous as you'll lose ALL directional control)
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Limited slip on the front wheels on ice and snow can be scary with tons of understeer, and plowing, I hated it. For not loosing speed at an autocross when one wheel lifts and the other wheel losses power, get the limited slip, if its for winter driving as mentioned above get good winter tires.
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
what type of LSD is it?... cone clutch, ramp type, viscous type, quaife?
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
trd
resident senior
Just make sure that when you change the diff that you purchase a new speedometer gear before you install the new diff . In case that you break the old one when removing it . Its cheap and could be a hell of a time saver . That is assuming that the Yaris speedo gear is made from plastic
Bathroom + Laptop = <3
check the classifieds, someone is selling a TRD one for around $650 i think and you can sometimes catch them on ebay for cheap money. Also remember the AE101 differentials fit as well. But if you do need one that is not used, i would recommend MicroImage all the way. Make sure you research the type you want, being helical,clutch,etc
#14 | |
Apexing Egg!!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
| NST End of Jan Sale ... Very limited quantities | NonStopTuning | NonStopTuning | 14 | 02-03-2009 09:50 PM |
| NST Thanksgiving Weekend Sale ... Very Limited Quantities | NonStopTuning | NonStopTuning | 16 | 12-03-2008 06:29 PM |
| Superman Limited Edition Yaris | St.Francis | General Yaris / Vitz Discussion | 6 | 10-13-2006 08:50 AM |
| Detailed dealer pricing on the new, 2007 Toyota Yaris. | tomjasz | New YARIS Purchase Forum | 3 | 08-11-2006 10:46 PM |
