![]() ![]() Drives: yaris sedan 2NZ-FE Join Date: May 2007
a tyre question
if i were to replace my 185/60/r15 on my yaris with 195/55/r15 would that decrease the cars power ?
Vroom Vroom Beep Beep
nope. actually makes circumference of the tire smaller. thus less time for one rotation.
no, no loss in power
does that do anything to your gas mileage? Putting smaller tires on?
Theory tells me it would, but I dont know by how much. ignore me please if this is a stupid question, lol |
would really affect economy....over size is pretty much the same....195-55 tire might be a bit heavier, but i wouldnt think itd be different enough to make any kind of a change except the wider rubber would grip better in handling...
185/60/15 = 23.7
195/55/15 = 23.4 205/55/15 = 23.9 This information is in the "official wheel and tire guide" in the sticky in this section. |
It would screw with your speedometer as well. Unless you hav a scangauge or something to correct it.
Drives: yw calls me douche and racist. Join Date: Aug 2007
i did it people , and i feel a great deal more handling and stability , i asked the Question because although the less time for rotation , theres a increase in rubber width .... so who wins?
PS : i didnt understand that ''23.7'' thing by kimona |
#10 | |
Speedo error is not of concern with these tyre size changes. In fact, there is speedo error right out of the box with the Vitz/Yaris with OEM 14, 15, and 16 inch diameter wheels/tyres. |
#11 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
as long as someone doesn't go too crazy it wont be a "real" problem. |
#12 | |
and how about filling the tyre with nitrogen instead of air which is better ? |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Some tires can be the same size but have a different total diameter. It depends on the tread depth. Some tires come with a 9/32 tread depth while some others might have 10/32 or 11/32. Some may be even more than that.
#14 |
l33t3st Asshole
also depends on the width wheel mounted and actual section width which isn't always the advertised # on the sidewall. :)
#15 | |
l33t3st Asshole
#16 | |
Start another Oil Thread!
i thought it was Centerlinium
you nailed it sir.
#17 |
Your bottom end and off the line acceleration will benifit slightly. Your top speed will decrease as well as your top end fuel milage. Larger diamter will give you higher top speed and better economy on freeway speeds. If you do local driving and no more than 40mph then you will benifit from this. If you speed most of your time commuting you would be better off with a larger diamter size. Especially if you drive a automatic which is already geared twoards city driving.
#18 |
Its not the rims that make up different dia. Its the rubber size.
| Transmission Question | CMR | General Yaris / Vitz Discussion | 42 | 04-14-2010 01:38 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 04:59 PM |
| this little thing cost me a new tyre | spinejaruk | General Yaris / Vitz Discussion | 21 | 09-19-2007 10:26 AM |
| dealer trade-in payoff question.. | kapo | New YARIS Purchase Forum | 1 | 07-16-2007 11:27 PM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 06:44 PM |
