Old 01-08-2009, 10:58 AM   #1
matthewboii
Drives: 2008 Flint Mica Yaris Sedan
Lowering JUST the back of the sedan
just a tiny bit,
what do you think of this idea?
i have noticed on the sedan it seems that the back wheels have much more space between tire and wheel well then the front, causing the car to look like the back wheel is somewhere around an inch smaller then the front... its obv just an illusion but i really dont like it, especially for when i plan to put new 17 inch wheels on, i will be extremely pissed if the back wheels look smaller just because of this...
so what do you think? and how much should the back be lowered?
matthewboii is offline   Reply With Quote
Old 01-09-2009, 12:38 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
Perhaps you should go with a mild drop all around.
I'd fear that the stock wheel well openings will look huge with 17's and low-profile rubber installed.
I installed TRD springs in my sedan. They're advertised at 1.2" drop but mine has settled at closer to 1.5" after a while. You might consider the Eibach springs which are advertised to drop 1" only.
Or just throw some junk into the truck to lower the tail only.
Old 01-09-2009, 02:25 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
A great mild drop is the Tanabe NF210 springs. They drop -1.2 front and -1.6 rear on the sedan. They ride great too...
Old 01-09-2009, 07:50 PM   #4
As Peter suggests, the Tanabes do even out the gap. Maybe the other brands do also, but I don't know.
Old 01-09-2009, 08:38 PM   #5
matthewboii
thanks ill keep that set in mind!
Old 01-09-2009, 11:30 PM   #6
matthewboii
having trouble finding the springs with those drop levels on the microimage site... are they there?
Old 01-09-2009, 11:35 PM   #7
matthewboii
nvm sorry didnt realize the site just has the numbers for the hb up
Old 01-10-2009, 10:27 PM   #8
PetersRedYaris
The sedan and Liftback use the same springs, though they drop each car a different amount. My earlier post is correct for the sedan drop...
Old 01-10-2009, 12:39 AM   #9
YarisSedan
Drives: 08 Yaris Sedan
Its because the way the rear fenders are. The easiest way to fix this is to get wheel spacers to bring the wheel out so its more flush with the body. Cause if you lower the car it will only make it more obviouse.
Old 01-10-2009, 11:03 PM   #10
That's correct, both cars share the same spring set up and the Tanabe part numbers are the same.
HELP! How to paint the horizontal silver/chrome garnish bar on the back of the sedan? songa Cosmetic Modifications (Exterior/Interior) 15 11-25-2008 07:11 PM
Where can i buy a lowering kit and spring 4 toyota yaris S sedan (4 doors) mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-07-2006 09:06 PM
