Old 02-01-2010, 09:03 PM   #1
Meteorite_Marty
Philips HID Kit - Help Needed
Hello Yarisworld,
I am considering purchasing a Philips 6000K HID kit, after researching and concluding they are the best (up for debate, but not here, not now please). Although the staff at http://www.autolamps-online.com (not a shameless plug) has been great in providing me details, I wanted to ask the Yarisworld members the more specific details relating directly to the Yaris.
Recently, I have been corresponding with their support staff, and have received and installation diagram that I would like some assistance with please. I am not sure where some of the wires would run to. If I relate it to my fog light install that I did using Toyota's manual, then I had to use a a relay in the interior fusebox, and a wiring into the engine fusebox as well.
Looking at the picture, is there anything like that to be done? Where does the relay go? What does the 20A fuse mean? Also, what does the bottom right diagram warning mean? Since the Yaris has this shield in the mirror housing, is the HID bulb going to hit it?
Please offer any relevant details to clear my uncertainty. Any help would be greatly appreciated. Thank you!
File Type: jpg Philips_H4_HL_HID_installation__Page_08.jpg (101.1 KB, 338 views)
Old 02-01-2010, 09:08 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
If you are purchasing a bixenon kit (HID for both Hi and lo beams), you will need to wire to a 12V lead. I simply added a relay off the battery, and have had no problems. I will advise you that I NEVER use the hi beams (the pattern is uneven) and the lo beams are awesome. If I did it again, I would only buy a single HID setup.
Old 02-02-2010, 12:19 AM   #3
you really should just buy a kit off of me...whats a phillips kit going to run you? H4 from me would be $100 for bixenon, I'm local, and when the weather is nice, I'd help you install it....i have just about every H4 colour in-stock right now too
the wiring is easy peasy....install is like an hour
Old 02-02-2010, 11:39 AM   #4
yaris0985
Drives: yaris sedan 09
the short side (see picture) go on driver side and long wiring on passager side, my I pass the cable just under the lacth (for open the hood) put some GOOD tie-wrap until the passager
What does the 20A fuse mean- because yaris have DRL (day running light) so like that your light and ballast does freak (because DRL work on 6v) not sure...the fuse is on the relay
if you speak french I already dit a HOW TO -
http://www.clubecho-yarisquebec.com/...hp?f=28&t=9377
yaris0985 is offline   Reply With Quote
Old 02-02-2010, 11:49 AM   #5
the hid's basically run off the battery and the relay acts as a switch off the stock wiring. so when the drl's come on, it switches on the circuit for the hids. so you have full power hid's as your drl's. i have this setup on my chevy aveo....i took out the drl module in the yaris...
the relay sits under my drivers side headlight
Old 02-02-2010, 07:51 PM   #6
Meteorite_Marty
Haven't bought them yet. They will run around $400.
Not saying I'm willing to pay this much, but the real deal seems to cost more.
I've read plenty of horror stories about fried electrical systems, flickering light patterns etc that I just want to be cautious/informed before making any purchases, and especially before doing any install.
Old 02-02-2010, 07:54 PM   #7
install is easy
i havent had any problems w/ my kit
Old 02-02-2010, 08:42 PM   #8
YAR1S
YAR1S's Avatar
EEKKK! Dont pay $400 for Hids !
the one's that Garm sells seem to be very good...
I've had mine for a few months and others have had them longer.
-Jen <3
Old 02-02-2010, 08:47 PM   #9
ozmdd
ozmdd's Avatar
Yeah...anything over $120 is too much for HID's these days. The stuff Garm and Barber are selling is no different than the phillips stuff, unless phillips is claiming their stuff is DOT-approved.
Old 02-02-2010, 09:58 PM   #10
arunto
arunto's Avatar
Drives: 2008 Yaris LB
I have the Bi-Xenons that Garm sells...they work great. Output and color are very good.
arunto is offline   Reply With Quote
Old 02-02-2010, 11:45 PM   #11
Meteorite_Marty
I was considering these. I know he sells top quality stuff. Do they work well with the mirror housings and plug and play with Yaris stock wiring?
Old 02-03-2010, 12:57 AM   #12
Focus_Sh1ft
Focus_Sh1ft's Avatar
I too would recommend these. The bulbs fit perfectly, everything is plug and play, and the lights themselves are great quality.
Old 02-03-2010, 08:33 PM   #13
Meteorite_Marty
So Garms can do high and low beams, hense "bi-xenon"?
How does that affect daytime running lights, dashboard display icons for low/highbeam?
Old 02-03-2010, 08:56 PM   #14
Focus_Sh1ft
Hi-beams symbol doesn't work. Dunno about daytime running lights.
Old 02-03-2010, 09:01 PM   #15
the ones i sell have a relay harness so theyll come on as drl's w/o flickering....i have h4 bixenons on my aveo w/ drls
seriously man, just buy 'em from me, ill take care of you. im sure garm and i buy them from the same place in china...
Old 02-03-2010, 11:41 PM   #16
Meteorite_Marty
I'm still considering even getting HIDs. I want to fully understand what I will gain/loss by going with as SET.
Can you comment on whether the dash symbols are lost for low/high beam?
Old 02-04-2010, 01:07 AM   #17
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Ok, so as this is my first car with bi-xenon lights, I have a couple questions.
I have had HID's in my last 3 cars and they have all been plug and play kits. I dont think I ever turned on my high beams with the HID's installed. The whole thing about relays and shit makes me hesitate on whether or not to buy them. However, I do love that with the bi-xenon kit uses the HID's as its drl's too!
1. Does the kit from Garm use the HID's as drl's as well?
2. Is Garm's kit plug and play?
3. thebarber, is your kit plug and play? if not how hard is it to install?
thanks guys
Old 02-04-2010, 09:43 AM   #18
high beam indicator doesnt work, no. it seems to be the way that the yaris is wired
thanks guys
my kits are plug and play
install is easy....took me about 30 or 45 min since its easiest to take off the bumper and headlights to get at everything...
HID Kit ecmiyake DIY / Maintenance / Service 5 12-12-2009 06:21 PM
XenithXenon HID Conversion Kit CorSport CorSport 0 09-03-2009 06:11 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 03:33 PM
