Old 02-01-2009, 04:32 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
What you think
planning on gettint the dc header and the underdrive pulley set think it will net me some good whp numbers? i already have trd exhaust and afe intake but dont really feel a diff
any other performance mods ideas are welcomed
Yoda is offline   Reply With Quote
Old 02-01-2009, 04:38 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
pulley set is very noticeable when installed
Old 02-01-2009, 04:53 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
+1 , the pullie set is a must do
and Black Yaris your aviator rocks
Old 02-01-2009, 05:42 PM   #4
Yoda
Yoda's Avatar
yea pulleys are must not sure about the header... lots of info on the subject was lost during the hack cant seem to locate it now :(
Old 02-01-2009, 06:12 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
it's been posted in the last couple days. people have claimed +3whp with pullies. so, about $100/hp
Originally Posted by xnamerxx
you nailed it sir.
Old 02-01-2009, 06:22 PM   #6
Yoda
Yoda's Avatar
hhmm ok so no header then. i cant remember once where some1 showed a dyno of header gains(excluding Richards). So is the header just a placebo for our cars?
Old 02-01-2009, 10:54 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
everything but forced induction and a tune is a placebo on the 1.5L 1NZFE
you nailed it sir.
Old 02-01-2009, 10:57 PM   #8
Black Yaris
der Zeck
says the man with a Turbo...
but a lot of little mods that add a tiny bit of HP all do add up.... don't add up to much, but it does add up
Old 02-01-2009, 11:06 PM   #9
Yoda
Yoda's Avatar
so dc header yes...no?
Old 02-01-2009, 11:08 PM   #10
Black Yaris
der Zeck
tell you the truth, I do not think anyone has noticed anything from installing a header... I sure did not
Old 02-02-2009, 12:31 AM   #11
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
I can't comment on the header by itself since I installed my header/cai/exhaust all at the same time, but there is a definite improvement on the top end. 5000 to redline feels much better. It does feel about the same as stock until you get past 3500rpm.
Old 02-02-2009, 09:05 AM   #12
Return of the Yarii
Drives: 2007 Sedan S
I had a DC Header and TRD exhaust installed at different times, header (at least the DC, cant speak on the others Megan, etc) had noticable increase at 3500 rpm-redline. Header has been since sold to Loren who I believe has noticed similiar gains as well. Maybe he can comment and confirm.
Return of the Yarii is offline   Reply With Quote
Old 02-02-2009, 09:31 AM   #13
yarstar
Drives: 2008 Absolute Red HB
I'm not sure why others didn't see this, but I saw a BIG difference when I put on my Weapons R 4-2-1 header. It went like this:
TRD catback = little change
AEM CAI = a little change
NST Pulley Set = a little more change
Weapons R Header = Big change!
This was just my experience.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 02-02-2009, 10:02 AM   #14
Yoda
Yoda's Avatar
how hard was the install. I heard the crank pulley is a pain to get off and some guy snapped his header after a couple moths due to a bad install....he forget to install the spring nut thingy..
Old 02-02-2009, 10:07 AM   #15
Return of the Yarii
Header is pretty straightforward, 3 bolt and 2 nuts + the 2 bolts/springs connecting stock manifold to the headpipe. There is also a lower bracket w/1 bolt and a small bracket holding A/F sensor wire. The A/F Sensor will need to be removed from the stock exhaust manifold and installed in the new header. Just a heads up many of us had the "crossthreaded" A/F Sensor and had to buy a new one because the stock one just cannot be removed.
Old 02-02-2009, 10:42 AM   #16
Yoda
Yoda's Avatar
so i goto by more stuff where do i get it? part number?
Old 02-02-2009, 11:09 AM   #17
Return of the Yarii
I bought header from Dan over @ We Sell Car Parts for $265. DC part number THC4407
I also purchased a brand new A/F Sensor from Ken over at Sparks for 170.25, Toyota part # 8946752020.
Hope this answers your question
Old 02-02-2009, 11:12 AM   #18
Yoda
Yoda's Avatar
yea thanks. why they make it crossthreaded? i wonder if it shows in the manual how to get it out. Hard to think they made it so it could not be removed
