Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 01-29-2009, 03:55 AM   #1
shtou
Drives: YARIS TS 1.8
1.8 TS and 1.5 yaris power&torque diagrams
i attach the diagrams of these 2 engine
i think for best performance is need to change the gear at 6000rpm.
for fuel economy i think the optimal change is at 3500rpm.
is correct?
shtou is offline   Reply With Quote
Old 01-29-2009, 10:05 AM   #2
run 'em to redline!
you want to stay in the power on the next gear....
but those piddly dynos are junk
in all seriousness....i find the 1nzfe noticeably runs out of steam past 6000 or so w/o mods. with just an intake i find it makes power to redline....
but for economy (and assuming youre not WOT) shift around 3000 or so
Old 01-29-2009, 05:23 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Agree, for the fastest possible acceleration you need to take it to 6,400 rpm
Whatch out for the rev limiter at around 6,600rpm. If you hit it the car will jerk out and there goes your pass.
And if you are concern about the Max fuel efficiency, we have a hole section about it on the forum. Is full of usefull tips.
The FE is not just shifting at 3,500rpm.., buch of things to concider if you want to achive Toyota's advertized consumption figures.
Old 01-29-2009, 06:22 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
does your DBW cut out at redline as awfully as the tC's do?
cable throttle FTW :D
Originally Posted by xnamerxx
you nailed it sir.
Old 01-29-2009, 07:41 PM   #5
CASTREX
CASTREX's Avatar
Yeap.... it takes a 1/100 sec for you to hit the rev limiter
Red ine is at 6,400 and you hit the rev limiter just passing 6,500rpm
Old 01-30-2009, 12:31 AM   #6
Yaris Palme
MAZDASPEED3
Yaris Palme's Avatar
Drives: MazdaSpeed3
Send a message via ICQ to Yaris Palme
the limiter came at 6555. tested on dyno.
Yaris Palme is offline   Reply With Quote
Old 01-30-2009, 02:33 AM   #7
CASTREX
CASTREX's Avatar
So it's just a 150 rpm window from red line to the limiter...
It will be nice if there was an easy way to increase the rev limiter... perhaps to 6,800rmp
With bolt ons we could really use that extra band legnth.
Old 01-30-2009, 02:52 AM   #8
Tamago
Tamago's Avatar
Drives: ZZW30
**************POP******************* goes the connecting rod..
i'll take pix tomorrow to show what happens when you over rev a stock-rod 1NZFE
you nailed it sir.
Old 01-30-2009, 06:34 AM   #9
Clode
Drives: Yaris in future
mhmhh
known a decrease of torque between 2000 and 3000
probably be solved with Camcon
Clode is offline   Reply With Quote
Old 01-30-2009, 06:42 AM   #10
Clode
wowow
fot 1.8
http://www.power-enterprise.co.jp/el...data_wish.html
Old 01-30-2009, 11:01 AM   #11
CASTREX
CASTREX's Avatar
Originally Posted by Clode View Post
mhmhh
There is no plug and play camcon app for the Yaris TS...
This info is from a different engine. The 1ZZ (Older Corolla engine)
Old 01-30-2009, 12:02 PM   #12
Clode
[QUOTE=CASTREX;231346]There is no plug and play camcon app for the Yaris TS...
are you sure?
call in Japan
Old 01-30-2009, 11:06 AM   #13
CASTREX
CASTREX's Avatar
mmmm I'm the kind of person that only learns first hand...
Plus a broken rod will provide you with a nice story to tell your friends..
J/K
Yeap this engine would not take over reving for much time. But it should hold some extra 400 rpm over a couple of 1/4 mile passes.
We will have to find out....
Old 02-17-2009, 09:43 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
news flash...
the 1NZFE is over 10 years old.. ask some echo, xa, xb owners.
you nailed it sir.
Old 02-19-2009, 12:27 AM   #15
CASTREX
CASTREX's Avatar
news flash...
News Flash!!! who is talking about the 1NZ engine???
The 2ZR it's been out for less than 2 years.... It could be as fragile as the 1NZ, but we don't really know.
No one has reported a Con Rod failure on any forum so far...
There is this guy who was drag racing in a boosted 2ZR. Ended up killing the engine after a few months but due to a lean condition @14 psi. But the rods held up with the abuse.
Old 02-19-2009, 02:20 PM   #16
PARIS
yaris dragster
PARIS's Avatar
Drives: YARIS 1.0 WITH LOUD EXHAUST
I have heard that all the new DUAL VVT-i have stronger blocks that the previous generation engines. The 1NR FE is less fragile than the 2NZ FE. The 2ZR FE is less fragile than the 1ZZ FE!
Anyway, what exactly did happen to that boosted 2ZR FE?
PARIS is offline   Reply With Quote
Old 02-18-2009, 01:32 PM   #17
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Ever take those pics??
Arkhangel is offline   Reply With Quote
Old 02-18-2009, 02:14 PM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
you nailed it sir.
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
[Photos] My car - Yaris 1.5 TS T-SportPT Photo-Video-Media Gallery 18 09-02-2007 01:46 PM
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 03:54 AM
Toyota Yaris, 1.5 YRX Auto Rudeshady Central and South America 6 06-15-2007 01:30 PM
