Old 09-23-2006, 09:23 AM   #1
Changing drum brakes to discs?
I'm in a bit of a quandary... The Yaris here is only available with a manual transmission at the lowest spec level (damn lazy drivers!), and this means a lot of options are not included in the car such as the engine start-stop button, etc etc, and the rear brakes are drum brakes :(
So for both esthetic and performance reasons, I'd like to change those to disc brakes. Question is, does this seem feasible at all? Should I try to put in the stock rear disc brake system from a higher-spec Yaris, or go for an aftermarket upgrade for all wheels (and, which are recommended?)
Thanks!
Old 09-23-2006, 11:52 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
I was looking into this a couple months ago.... I thought I had found a direct replacement kit.... but I'm not sure. I will take another look and see if i can dig somthing up
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 09-25-2006, 12:17 PM   #3
ScottFern
Drives: 2007 Yaris Sedan
Great question. In for an answer!
ScottFern is offline   Reply With Quote
Old 09-25-2006, 04:45 PM   #4
ChinoCharles
Drives: LB
Yay for this thread!
Old 09-25-2006, 05:16 PM   #5
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
etimago, don't be sad... we have rear drum brakes for our 07 yaris as well. they make the car cheaper by putting drum instead of discs.
jeff_o is offline   Reply With Quote
Old 09-25-2006, 05:17 PM   #6
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Same problem here too.
I have purchased the most expensive model (Sol+) and the rear brakes are drum brakes.The greek Toyota Co. installs normal brakes at the back only if the car is equipped with traction and stability control.
