Old 12-11-2008, 01:07 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Squealing brakes when cold?
I've noticed that my brakes tend to make a squealing noise when I first drive the car. It sounds like it's coming from the driver's side rear. Anyone else have this issue?
I'll most likely bring the car into the dealer so they can then tell me it's a normal wear-and-tear item and they won't fix it (how's that for optimism?).
Old 12-11-2008, 02:14 PM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
same here, just the 1st pulling out of the driveway, i think we discussed this already tho... Had to do with parking with the parking brakes and not the ebrake?
Its a Chao!!!
Old 12-12-2008, 08:20 PM   #3
Thirty-Nine
Yep, it's just the first time I pull out of the driveway. (BTW, the parking brake is the e-brake, no?)
I'll just bring it in.
Old 12-16-2008, 10:46 PM   #4
buchieboy
Drives: Toyota Yaris
Min has the same case, will bring it for servicing over the weekend.
Does your stop squealing after the first few brakes?
buchieboy is offline   Reply With Quote
Old 12-16-2008, 11:33 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
Whens the last time your rear brakes were cleaned and adjusted. Backing plate probaly just need to be lubricated and all the dust from the drums need to be cleaned out. Very common problem if it happens when cold and goes away when its hot. After you brake a few times the brakes get extremly hot and everything expands. WHen cold the gap between the pad and drum is greater. SO once they are adjusted properly the gap will be gone even when cold
Old 02-10-2009, 06:46 PM   #6
Thirty-Nine
Back from the dead ...
Bringing the car in tomorrow to the dealer; we'll see what they say. I hope they don't give me the runaround about "brakes are a wear-and-tear item," so they won't fix the noise under warranty.
Old 02-10-2009, 06:49 PM   #7
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
for me they did a rear brake adjust and noise went away....
Old 02-10-2009, 06:52 PM   #8
Thirty-Nine
I'll be sure and mention that some people I know just need the brakes adjusted.
Old 02-10-2009, 06:55 PM   #9
BLAZINBLUEVITZ
adjusted brakes and the ebrake handle as well.....
Old 02-10-2009, 06:57 PM   #10
Thirty-Nine
Cool, thanks!
Old 02-11-2009, 07:06 PM   #11
Thirty-Nine
FYI, Beaverton Toyota adjusted the brakes, no questions asked. That was easy.
Old 02-12-2009, 08:48 AM   #12
BLAZINBLUEVITZ
did they like the orange wheels and did they check for the new recall.....
Old 02-12-2009, 12:14 PM   #13
Thirty-Nine
Haha--yes they liked the wheels. However, they did not check for the recall.
Old 02-12-2009, 01:38 PM   #14
1stToyota
1stToyota's Avatar
Mine does it only when it's cold and damp. Goes away by the time I'm backed out of the garage and down the driveway. Mine is due to a little rust buildup on the drums, goes away after the shoes clean off the rust; just normal for the weather conditions.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-12-2009, 02:49 PM   #15
Nagoya_TRD.
Drives: None.
Sorry for the stupid question, do Yaris's have only drums in the rear or is there a 4 wheel disk option?
Nagoya_TRD. is offline   Reply With Quote
Old 02-12-2009, 09:00 PM   #16
Thirty-Nine
At least in the U.S., drums are the only available rear brakes.
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 07:04 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 08:58 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 06:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 05:17 PM
