Old 02-28-2009, 02:02 AM   #1
silver_echo
ekodrvr
silver_echo's Avatar
whistle?
anyone else notice the slight whistle from the intake manifold? normal? i think that it is normal as i have heard it on other echos that i see as well as 1st gen xBs and xAs... very low on gas pedal pressure, usually low in RPM almost sounds like a vacuum leak, but no codes, and it only sounds at a specific pedal point...
silver_echo is offline   Reply With Quote
Old 02-28-2009, 02:24 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
it's a common noise, usually louder when you have an intake.
Old 02-28-2009, 02:53 AM   #3
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Just in case, check for holes or breaks in the rubber/plastic.
Old 02-28-2009, 02:56 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
you'd have a CEL if there were leaks between MAF and engine.
Old 02-28-2009, 03:16 AM   #5
rningonfumes
Not necessarily, had the rubber on my Camry's 4cylinder go bad, took me a week realize the NEW (lol) whoosing/wheezing sound was a tear-- no CEL. Then again the Yaris is newer, you could be right.
Doesn't hurt to look, does it?
For the record, I don't hear any sound from my stock unit.
Old 02-28-2009, 03:18 AM   #6
silver_echo
ekodrvr
actually mine is an 01 echo... same car, same motor, and has been doing it since i got into it with 10k miles just never really bothered with it... i think it has something to do with the fact that the intake manifold is plastic
Old 02-28-2009, 03:18 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
he's an echo
shares ECU(kinda) and throttle body with me. y'all are DBW and use a different MAF etc.
Old 02-28-2009, 03:19 AM   #8
silver_echo
ekodrvr
have to say it, HAHA i typed faster!...
Old 02-28-2009, 03:23 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
same engine block, but very very many differences between the yaris 1nz and our (echo and xa/xb) 1nz... learning more differences every day :(
Old 02-28-2009, 03:25 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
3:18 > 3:18 :(
Old 02-28-2009, 03:32 AM   #11
silver_echo
ekodrvr
aren't they all the 1nz-fe? should be the same all the way across, and it looks like the same manifold one the yar
Old 02-28-2009, 03:40 AM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
no sir.
different intake manifold
different throttle body (theirs is drive by wire, ours is obviously cable)
different mass airflow sensor (we have an older denso unit, shared ironically with the STI)
etc etc. the list goes on.
