Old 02-20-2009, 11:40 PM   #1
Lafiro
Drives: 06 Yaris Sedan
Help please, can't get my rims off!
I seem to have misplaced the tuner lug key I got when I purchased a set of ADR rims with the lug nuts. I can not seem to find a place to buy this.
If someone can please help me find a place to purchase a new one, it would help a lot!
I believe toyota kept it last time I went in, but they dont want to even check or ask around.
Old 02-20-2009, 11:55 PM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
bro you gotta contact the company that made the lug nuts......if it's toyota/mcgard they definitely have an extra lug key for a fee.......
i mean if we had a key to your lug nuts......what would be the point?
dang....four lug nuts that need a key! those rims must be worth$!!!
if you can't find the key.........the mech might have to burn it off......at a price of your rims i believe.....not sure
hope everything goes well
Yawesh is offline   Reply With Quote
Old 02-20-2009, 11:58 PM   #3
texkid
The one with cheese on it
Drives: '10 Corolla S
Who was the last person to use the keys? I am thinking maybe somebody put a spare key in one of the compartments? The dealerships usually don't keep spare keys for wheels, I think?
texkid is offline   Reply With Quote
Old 02-21-2009, 12:01 AM   #4
supmet
Drives: 2007 4 Door Yaris
if you know anyone that works in a machine shop they could probably make one for you. those don't look that tough to make. (looking closer you might even be able to stick an extender in there with no socket on it, or weld a nut to the end of an extender)
but I would definitely talk to the company that made them and see if you can get a new key.
Here's the contact info if you haven't already found them
http://www.adrwheels.ca/
"ADR wheels are the flagship wheel line distributed by Golden Apple Corporation. "
http://www.adrwheels.com/about.php
Golden Apple Corporation Headquarters
3532 Arden Road, Hayward, CA. 94545
Phone: 510.780.9800
Toll Free: 800.745.1836
Fax: 510.780.9899
Old 02-21-2009, 12:10 AM   #5
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
the place that did my wheels put an extra tool by my spare. hopefully the same happened to you?
Club SHIFT
Old 02-21-2009, 12:11 AM   #6
Lafiro
Well, maybe I used the wrong term? Its just a conversion from the type that goes into the lug nut, to the standard outside size like all other stock lug nuts. Thats all it is, just a chunk of metal to upsize the pattern pretty much. There are no lucks or anything.
I remember I thought I lost it once and this guy had a bunch of different sizes and was about to charge me $35 for a new one until I found it on the floor a minute later.
Old 02-21-2009, 12:15 AM   #7
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
most tire shops will have a lug keys for sale, since it seems you do not have locks, just tuner style lugs. I stripped my lug key a few years back and i bought one at a local wheel and tire shop for $5. I think i may have a few lying around.
Old 02-21-2009, 12:29 AM   #8
Lafiro
Thanks, I will drive around tomorrow after class to see if I can find one.
Old 02-21-2009, 12:45 AM   #9
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
looks like a standard or metric HEX socket not a torx socket but a hex with flat sides....
Old 02-21-2009, 01:07 AM   #10
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
ohhhhh, ic
Old 02-21-2009, 02:03 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
I used to work at a tire shop. I kid you not one mechanic had an entire tool box drawer full of wheel locks. You would not belive how many times mecahnics have forgot to put the wheel lock back and left it on thier impact gun or by the wrack to find it later on.
More than likely it was forgot to put back. You can go to any tire shop they should be able to look up your wheel lock set and order a new one. Or more than likely they will have a key laying around for it =). Or you can have them broken off and a new one orderd. I usually charge 10 dollars a lugnut at my shop to break off. But since you have an entire set it could be pricey.
Old 02-21-2009, 05:21 PM   #12
Lafiro
No, its not a lock!!!!! Its just plat in the inside, its just a hex size conversion. Instead of it being like 3/4inch think outside like most lug nuts are, its like 1/2inch inside, so its just a downsizer to connect to the impact gun to get the lug nuts off and on.
That is what I am missing. But hopefully I can find one somewhere.
Old 02-21-2009, 08:45 PM   #13
andruboz
boohachimono
Drives: 07 hb
Send a message via AIM to andruboz
so you just need one of these?
andruboz is offline   Reply With Quote
Old 02-21-2009, 09:01 PM   #14
*MAD DOG*
*MAD DOG*'s Avatar
The way to get these off is easy.
Find a socket that is just a little too big to fit around the outside of the nut. Put some cloth or cardboard in front of the socket and then whack it on using a hammer, remove nut and repeat the process.
That is how I got them off my old car.
Old 02-21-2009, 09:09 PM   #15
andruboz
boohachimono
Drives: 07 hb
looks like you could get a key and a pile of lugnuts you don't need on ebay for $18.00
http://cgi.ebay.com/ebaymotors/20PC-...QQcmdZViewItem
18in rims keshaw.sharma Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 11-02-2008 02:15 AM
RIMS REPAIR SHOP? Blenjar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 09-27-2007 06:17 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 10:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 02:25 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 04:16 PM
