In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
engine swap complete!
Got back the car today, runs great very smooth. runs a bit better than my old engine. Got alot of parts from it so i'll post it for sale when i got through all the items. The old engine still had water in it the flywheel and clutch were rusted due to all the water and has to be sand blasted they where still in very good condition. Put all new spark plugs but instead of ngk when with bosch, new transmission fluid, flushed and replaced with new coolant, but used regular oil for now i'll changed it to synthetic after 5000km to see how it goes.. Only think is i'm getting a low whinning noise, like a turbo spooling up. Thinking it could be normal or maybe the ac compressor pulley still has water. or the alternator pulley? Maybe it has to do that it an 07 engine in and 06? not sure. I'll keep a check on it.
Couple of things the exhuast donuts doesn't last long i was at 119000km and it was finished. The exhuast joint for the headers to the downpipe rust very fast, but the rust of the exhuast system is fine, even the joints under the car was in better shape than that one after being in so much water. Also if you have to change you axle you'll need a special socket to remove it a 16 point 24mm socket. all ask to shop to be sure but it special size that only toyota has. One expensive lesson! No more cold air intake for me. At least for everyday use. Maybe on the track. |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 07:21 PM |
| Need help badly looking for engine swap places in gta | Adriaan | Canada | 7 | 02-23-2009 09:14 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 11:53 AM |
| 07 Yaris 3DR / 2ZZ-GE Engine swap possible? | Chillinmofo | Performance Modifications | 1 | 06-10-2007 03:57 AM |
| if i am thinking about an engine swap - from 1.3 to 1.5 - please help | ASHRAF | Performance Modifications | 15 | 01-03-2007 02:40 PM |
