Old 02-27-2009, 12:38 AM   #1
84masters
Drives: 09 3dr,base,5sp,trd sway bar.
195/55/15 OR 205/55/15?
will these fit on the stock steel wheels...with no rubbing?
any warranty issues when you change tire size?
thanks....
going for a set of nokian wr.
84masters is offline   Reply With Quote
Old 02-27-2009, 12:38 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
yes
no
don't.. get a better tire than a nokian if you're gonna spend the money
Originally Posted by xnamerxx
you nailed it sir.
Old 02-27-2009, 09:32 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
No worries with 195/55/15 or 205/55/15 on stock steel wheels.
Check here for information about tyre sizing: http://www.yarisworld.com/forums/showthread.php?t=5021
Old 02-27-2009, 10:08 AM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
205/55/15'S WILL RUB with stock wheels. not much but it does rub.
Old 02-27-2009, 10:12 AM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
where specifically does it rub, and on what suspension?
you nailed it sir.
Old 02-27-2009, 10:26 AM   #6
BLAZINBLUEVITZ
im running tein's and it rubs on the lower fender well i believe. it usually happens when i turn wheel too far left or right like when making u-turn.....
Old 02-27-2009, 10:29 AM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i have 205/55/15 on my wheels lowered on df210s and it rubs at full lock and high speed (55+) dips
Old 02-27-2009, 10:32 AM   #8
kimona
kimona's Avatar
You'll get very minor rubbing lock-to-lock, which is pretty common on many set-ups with the Yaris. The good news is that we rarely lock-to-lock, and when we do, it's only briefly and at almost stop speeds. With 205/55's on stock suspension and wheels, there are no rubbing issues to worry about.
Old 02-27-2009, 10:44 AM   #9
BLAZINBLUEVITZ
i have no problems at high speed just the LOCK TO LOCK as its refered.
Old 02-27-2009, 10:47 AM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
what is the tire rubbing on at full lock? smooth surface or plastic? no harm there :)
you nailed it sir.
Old 02-27-2009, 10:53 AM   #11
mikenacarato
SIPNDEW
Drives: 15 STI
the middle of the fender lip and the center of the front and rear splash guards. but i guess that depends on the wheels offset of they are aftermarket too, so stock would be different. like i said though, i have aftermarket 15s which are wider, not factory steel wheels.
Old 02-27-2009, 12:20 PM   #12
BLAZINBLUEVITZ
SO, your saying it rubs on the REAR mudguard as well?
Old 02-27-2009, 12:44 PM   #13
kimona
kimona's Avatar
The rubbing is on the plastic fender liner and it is extremely minimal. It occurs only sometimes in a lock-to-lock maneuver and is nothing for concern.
Old 02-27-2009, 12:49 PM   #14
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
thanks....
I got 205/50/15 a mid point between the 2 you are asking for, and with OEM sport wheels and lowered with NF210s I have no rubbing at all!
CLA 250, 4MATIC
Old 02-27-2009, 05:05 PM   #15
kimona
kimona's Avatar
Actually, 205/50'a are not "mid point" but are shorter than both the tyres we're discussing. 205/50's work well on DF's, for example, but no need to run that short with stock suspension or a mild drop.
205/50/15 vs. 205/55/15: pics? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 07-14-2007 09:44 PM
