Drives: yaris Join Date: Mar 2014
2012 dash swap 2007
Is it possible to swap 2012 dash with cluster and everything into 2007 yaris? Any one done ?
It would not be a practical thing to do. You would have issues with fit as well as you would have to change over the entire wiring harness to make everything work properly.
It would be interesting to see a complete 2012 interior in a 07 though.
I would rather go the other way and have the center speedometer on a third gen.
#7 | |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
It's popular with the VW crowd to put for instance a Golf III dash into a MkI, or a Corrado dash into a Scirocco, but that's only possible because of a totally different approach to the design.
For instance, you can get programmable intermittent wipers in a '84 Rabbit MkI simply by plugging the relay module from a '08 New Beetle into the empty spot on the relay and fuse block, thus upgrading your wipers from on/off to off/programmable intermittent/slow/fast. Try that with a Toyota. So you can just saw the ends of a Golf III dashboard and stuff it into a MkI Scirocco, plug everything in and it can be expected to work. On our Yarii? Fugeddaboudit. |
#9 | |
you only need to swap a prius wiper stalk in, and voilą.. variable speed intermittent. or from a 07+ camry if you have a sedan.. edit: you don't get intermittent rear wipers, but i believe CTScott had made a module that will do it. |
#10 | |
Another Prius part that fits elsewhere is the rear wiper, to give the Scirocco II's rear a more modern look ;) |
![]() Drives: 2005 NCP91 Vitz Join Date: Mar 2014
Anything is possible if you try, wiring would be simple enough, maybe have to depin and repin a couple of different plugs but all wiring colours would be the same so easy enough particularly if you could find complete wiring diagrams for the two.
You would just need to figured out what parts you need to make it work, i.e. front door cards need to match up to dash shape to allow doors to close etc |
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
its far easier to swap an xd dash with a 2nd gen. look into that.
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
The cars both have differently sized and shaped interiors. You would need lots of expensive custom work done. The type of skills you see on the show "Pimp My Ride". It's particularly complicated in this case because one has center gauges, the other behind the wheel. Don't even think about this type of undertaking. The car isn't worth it.
#15 |
![]() ![]() ![]() Drives: No more Yaris Join Date: Dec 2013
The days of whole sections of cars being interchangeable, are pretty-much gone.
In the past, a facelifted car would leave whole sections of it unmodified; the new fenders bolted up to the same cowl; the doors were the same even though front and rear sheet metal was changed. That doesn't seem the rule anymore. The Gen3 Yaris is the same size; almost the exact same...but everything has been tweaked. The doors are different. Seating positions are different. The dash is drastically different; and like Mr. Scott, I'd prefer the center-pod speedo and all those trays and storage areas. The cowl has been redone and the windshield glass is different. One wiper versus two. So, no - I'd bet that without expensive mods and fillers and cutting, the dash would not interchange. If you really want a Gen3 dash, buy a Gen3. It drives better, IMHO. More precise steering and an improved seating position. So...put your Yaris on Craigslist and start shopping for a new one. |
#16 |
^ You are talking about facelift, not new gen.
gen2 yaris include 06-08, and 09-11 (facelift) in North America. 12+ are gen3, which is a complete redesign. |
| Radio swap from 2012 LE/SE into a 'L' | richard_rsp | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 02-18-2014 12:20 PM |
| 2007 yaris snow tires on 2012 | lomky | Third Gen Yaris General Discussion | 4 | 11-16-2012 03:00 AM |
| Buyout 2007 or lease 2012? | Walnutcrunch | New YARIS Purchase Forum | 11 | 06-03-2012 03:19 PM |
