![]() Drives: Toyota Yaris 2007 Join Date: Mar 2009
Yaris Tire Pressure Help
Hello everyone
I am new to this forum and just recently bought my first car. It is a 2007 Toyota Yaris 1 Ltr My question is if anyone knows what the standard tired pressure should be for the my car? I think it is 32psi but I would be grateful if you could help me. Thanks for reading :) |
should say in the doorjam what pressure to run... :)
32-34 should work ok
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
The tires have a max pressure number on them. I use that minus 2lbs for (what I feel is) best grip and best fuel mileage, without overstressing the tires.
#4 | |
do NOT run your tires at 48psi lol
Drives: 2007 4 Door Yaris Join Date: Jan 2009
#7 | |
too-high pressure, best mileage, no grip, improper tire wear too-low pressure: better grip in a straight line (softer sidewall) but worse grip laterally (softer sidewall) improper tire wear optimal pressure: best compromise of economy and grip.
"Optimal pressure: best compromise of economy and grip." I thought that is what I said; it is what I meant to say. I am getting good grip and excellent FE by running my OEM tires ~4lbs over recommended pressure, with no unusual tire wear pattern.
Then the whole thing goes sideways when you see what the hyper-miler guys are running! |
This is what you said. I don't know about your tyres, but mine indicate a maximum tyre pressure of 50PSI. So, 50-2 = 48PSI... which would be somewhat overinflated. If I inflated my tyres to 48PSI, I'd be bouncing all over the road like a basketball!
Should have a label affixed to the driver's door jamb that indicates tyre pressures and loads. Label on my Vitz clearly indicates 32PSI front/rear.
| Tags |
| psi, tire presure, yaris |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Im in Yaris heaven..... (Special Edition Yaris) | YAR1S | Photo-Video-Media Gallery | 77 | 06-16-2010 10:55 PM |
| Tire Pressure Monitor Sensors....? | 09TRD | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-19-2008 09:25 PM |
