Old 03-05-2009, 11:12 PM   #1
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Water pump belt and pulley - replaced at 36,000mi
During a routine inspection I noticed my belt was starting to wear:
So bought a replacement belt, and since the shop also recommended a change of the water pump pulley I bought that as well.
Basically no dramas after that, US$50 for the parts, and $20 for half an hour of labour at the local garage fixing it up. Here's how the worn parts look closeup:
Note the groove that's been worn in. This is a steel part. If you're using lightweight aluminium aftermarket pulleys do check yours regularly - this is consumable
Check out the crack that is forming in the belt
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
