Old 03-15-2009, 01:43 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Which rim offset would you pick???
I am looking for a lightweight 15" rim. There are a few choices and I am trying to decide which would work best for me.
I use 195/55/15 Michelin Exaltos
Would you guys choose +35,37,41, or 42?????
The Enkei RPF1 are the most reasonable $200 and about 9.5lb!
Thanks in advance
fuji is offline   Reply With Quote
Old 03-15-2009, 01:52 AM   #2
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
How wide? +42 is good for a 7" width.
Old 03-15-2009, 02:58 AM   #3
fuji
fuji's Avatar
Cool, the 42+ offset wheels are 15x7!
Old 03-15-2009, 03:01 AM   #4
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I have +42 for my 16x7" ssrs. Could use a 10mm spacer in the rear, but no biggie.
Old 03-15-2009, 10:00 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
With ET42, you're safer up front to run 205mm tyres in the future.
Old 03-15-2009, 01:45 PM   #6
fuji
fuji's Avatar
With the 195/55/15 ties, will a +35 be a problem with rubbing in the front???
Old 03-15-2009, 03:04 PM   #7
kimona
kimona's Avatar
Would you like to tell us something about your suspension set-up first?
Old 03-15-2009, 06:14 PM   #8
fuji
fuji's Avatar
I am using NF210 spring in front - mild 1.1" drop
Old 03-15-2009, 07:10 PM   #9
kimona
kimona's Avatar
I wouldn't go lower than ET37 (up front) with a 195mm tyre.
If you're not into rotating, you could stagger the offsets for a better fitment. It's a very common practice in Japan.
Does Rim offset affect performace? bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 01-02-2009 03:31 PM
Can't seem to pick rim color ZING Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 12-16-2008 11:49 AM
offset... Keymaster Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-01-2007 02:53 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 04:25 PM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 04:43 PM
