![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Does the TRD rear sway bar promote tire wear?
Just wondering if the sway bar promotes tire wear on the rear tires outer edges? Aside from taking turns faster, that obviously would wear out quicker but since it keeps the rear firm and less sway when the car turns, does that put more weight on the outer edges instead of letting the rear torsion bar just flex a bit more thus not putting more force on it?
Break'em off some.
No, you won't see any more wear than normal provided you keep the same driving habits.
What?
There's the kicker. The rear swaybar is likely to inspire you to corner harder and faster, which will increase tire wear.
But, the bar in and of itself won't affect tire wear at all. |
Apexing Egg!!
i cant believe how often this comes up! maybe stick this in the suspension primer? a "what effects tire wear" category perhaps?
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD sway bar and tire wear | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 02-01-2009 08:07 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| Difference b/w TRD Rear Sway Bar and these? | IsLNdbOi | Performance Modifications | 8 | 11-11-2008 09:13 PM |
