Old 07-16-2011, 05:48 PM   #1
larryn2o
larryn2o's Avatar
Drives: 08 yaris
hesitation problem
is there a cure for a hesitation just off idle? car has done it since new and is getting worse. it feels like the torque converter is disengaging and will make the car lunge forward unexpectedly.
thanks
larryn2o is offline   Reply With Quote
Old 07-16-2011, 07:50 PM   #2
Liu997
Drives: 2008 Red Yaris LB
Yeah, mine has been doing it since new also. I don't think there is a way around it. It is especially bad when nearly stopping from a high speed and accelerating again.
I believe that the transmission is just downshifting. There is no way to eliminate the effect but I noticed when I changed the transmission fluid that it is slightly less problematic.
Liu997 is offline   Reply With Quote
Old 07-17-2011, 01:48 AM   #3
thepartsmancometh
Drives: '08 LB, '07 WRX
sometimes, issue like this can be a "learned" response from the ECU. I had our master tech check my wife's yaris out because of a throttle hesitation (or, more accurately, a lack of sensitivity). We tried everything: swapping the gas pedal, swapping the t-body, etc. I finally fixed it by unhooking the battery (for an unrelated install) and resetting the ECU. its worth a shot.
thepartsmancometh is offline   Reply With Quote
Old 07-17-2011, 08:58 AM   #4
+1 on the learned response.
After installing my supercharger I reset the AT memory in the ECM (this can only be done with the TechStream tool) and it made a huge difference on how and where the transmission shifts. The AT learning occurs during the first 15 minute drive cycle, so even when buying a new Yaris it is possible to miss that opportunity if the dealership does a checkout drive with your car.
Unplugging the battery for a couple of minutes will reset the short term fuel trim, but will not reset anything in regards to the transmission.
Old 07-20-2011, 10:46 PM   #5
larryn2o
larryn2o's Avatar
Drives: 08 yaris
thanks for the feedback , sounds like i need to get ahold of a Techstream tool.
Old 07-21-2011, 07:24 AM   #6
bronsin
bronsin's Avatar
My Yaris (and my wifes 2005 Camry) do not make smooth transitions when they start moving. You have to push on the gas pedal quite a bit and even then the car doesnt move right away. When it does it tends to be faster than you would like because you have pressed the gas pedal so far to initiate movement.
Is this the same thing you guys are talking about?
And will resetting the transmission help?
WHat is this Techstream tools so I can look it up on the internet?
Thanks!
Old 07-21-2011, 07:31 AM   #7
Thanks!
The deadband on the throttle is mostly due to the drive by wire throttle, and that is significantly helped by a throttle controller, like cammell is talking about.
How the AT shifts between gears is the part that is learned by the ECM. The TechStream tool is Toyota's computer based diagnostics tool.
Old 07-21-2011, 11:32 AM   #8
bronsin
bronsin's Avatar
How do you install it? Where does it go!
And where can I get one?
Old 07-21-2011, 12:03 PM   #9
bronsin
bronsin's Avatar
pm sent
Old 07-21-2011, 08:47 PM   #10
camelll
Drives: 07 sedan
Sorry guys the throttle controller is sold.
camelll is offline   Reply With Quote
Warrany Service Problem? 2009Yaris General Yaris / Vitz Discussion 4 03-31-2011 05:56 PM
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 06:12 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 05:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 04:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
