Old 04-04-2009, 02:21 PM   #1
othater
Drives: 07SedanS06Taco
ignition keyring light
Wondering if anyone has added a ignition keyring light?
I'm getting old..Can't see in the dark
I did a search here and nothing.
I found one thread on Scionlife for a XA/XB, being a toyota product. http://www.scionlife.com/forums/viewtopic.php?t=81354
Thanks
othater is offline   Reply With Quote
Old 04-04-2009, 03:21 PM   #2
always check my store
http://shop.microimageonline.com/pro...3&productId=61
Old 04-04-2009, 04:06 PM   #3
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Garm have you gotten white??? (I feel like chase you around the forum)
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 04-04-2009, 05:07 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Hi guys just so you know , this will not fit the yaris if you have
factory keyless entry as there is a start disable module in this area .
picks up trasnponder signal from the key.
Old 04-04-2009, 05:58 PM   #5
othater
Cali Yaris,
Blue will match my led mod (radio, speedo cluster) perfectly.
Can you confirm this will fit a U.S. sedan?
and is this tied into the dome light with instructions?
I dont believe U.S. model has what 1NZyaris1 is talking about.
Thanks
Old 04-04-2009, 06:43 PM   #6
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
factory keyless entry as there is a start diable module in this area .
Thanks! that way I don't to buy it for the SD just the HB
R-CaT
Project Yar 2ZR
Old 04-04-2009, 11:00 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by othater View Post
Cali Yaris,
Thanks
it will fit us sedan. all sedan prior to 09
Old 04-04-2009, 11:41 PM   #8
IsLNdbOi
IsLNdbOi's Avatar
Bummer. Was just looking at it at the Micro Image online store today, but my '09 has factory keyless entry.
Old 04-05-2009, 02:04 AM   #9
IllusionX
i'm not sure if all US 09 have immobilizer (chip in the key). but if you do, then you should have a red light flashing by the windshield. (you'd see it from outside).
If not, then the ring will fit your yaris.
note: all new cars sold in CANADA have an immobilizer. it is required by law.
Old 04-05-2009, 04:19 AM   #10
IsLNdbOi
IsLNdbOi's Avatar
Yeah, I do have that red LED on the driver side end of the defroster vent right below the windshield.
Old 04-05-2009, 04:39 AM   #11
Benggolf2
Benggolf2's Avatar
factory key less entry as there is a start disable module in this area .
picks up transponder signal from the key.
Shucks, our HB has key less entry. Guess, this kills my idea of installing one.
Thanks for the heads up anyway, 1NZYaris1; saves me the trouble of returning the part.
Benggolf2
Old 04-05-2009, 05:03 AM   #12
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Yeh i know that feeling , i bought one, and when it turned up it looked like
it had been run over , broken into about 6 peices ,so i super glued it back togeather just to try it , fitted great it even lite up okay but i had to
remove the factory part from the barrel hense the car would not start.
as the inner ring looks like it gets it's earth from the ing barrel.
Old 04-05-2009, 11:09 AM   #13
IllusionX
re read my post above, the problem is NOT the keyless entry.
all new cars sold in Canada since 08 have an immobilizer, regardless you have keyless entry or not.
even then 9999$ hyundai accent have an immobilizer.
Old 04-05-2009, 11:47 AM   #14
Thanks for all the great info guys, I will post the warnings withe the product description.
I'm still not clear though, why you couldn't just wire it to the dome light wiring? I'm reading that "it won't work because", but I don't understand completely. Will it just not fit?
Old 04-05-2009, 09:41 PM   #15
IllusionX
Well, it looks like there is already a ring at the ignition. so you can't fit a 2nd ring on top of that.
see pic above.
Old 04-06-2009, 02:10 AM   #16
IsLNdbOi
IsLNdbOi's Avatar
My '09 LB has a transparent plastic ring where this ignition key light would go. Couldn't we just remove that and pop this ignition light in place of that transparent one I have? Or is the keyless entry still going to prevent that?
Old 04-06-2009, 02:30 AM   #17
BailOut
Steals terrorist's lunch
BailOut's Avatar
You don't need an ignition keyring light. Just above the rear view mirror are two lights. One will shine right on the ignition keyring when activated.
- Brian
Share the Road
Old 04-06-2009, 02:31 AM   #18
IsLNdbOi
IsLNdbOi's Avatar
Of course we don't need an ignition key light. Who told you we needed one?
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
LED ignition light Jsword Cosmetic Modifications (Exterior/Interior) 17 10-21-2008 05:54 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
