Old 04-13-2009, 05:18 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
Smile what does it mean, "the clutch slips"?
Is it when you put in 1st gear and you start going and it feels like the tires are burning out but they're really not?
Syroyizhka is offline   Reply With Quote
Old 04-13-2009, 05:44 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Yes. The engine is turning over, but the car's speed, in gear, doesn't match the RPM of the engine. When you shift, let out the clutch quickly while gunning the engine, and if the car doesn't accelerate, it's slipping.
Old 04-13-2009, 06:11 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
time for a new clutch
Old 04-13-2009, 09:57 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
easiest way to find out is try gun it on 3rd.
rev it to ~3000rpm, if your car stalls, then your clutch is still good.
that's what Toyota did back in 2005 when i told them the clutch of my 05 echo is slipping. It never stalled, and just went as if it was on 1st :P
Old 04-14-2009, 02:27 PM   #5
Syroyizhka
Syroyizhka's Avatar
my friend's old car used to do that, hopefully that won't happen to my Yaris, that's expensive to get fixed isn't it, he ended up throwing the car away :)
Old 04-14-2009, 02:35 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Replacing a clutch is normal, expected maintenance with any manual transmission, just like replacing tires and brake pads. Taking care of your clutch by not slipping it any more than absolutely necessary, never using it to hold the car on hills, not making "dragster starts" and never using it to reverse motion (that is, fully stop when you're backing up before you put it in a forward gear to drive away) will make it last much longer. But eventually it's got to be done.
Old 04-14-2009, 10:52 PM   #7
Syroyizhka
Syroyizhka's Avatar
just curious wen this sad day comes n i have 2 buy new clutch, how nuch is it?
Old 04-15-2009, 12:16 AM   #8
tomato
tomato's Avatar
What he said.
Sorry, I don't know how much it costs to do that on a Yaris, sure would like to know, as well.
Old 04-15-2009, 09:24 AM   #9
IllusionX
100-200$ i guess, depends what you buy.
but, you shouldn't need to change clutch before some 100,000 miles, unless you are a good clutch rider :P
Old 04-15-2009, 01:30 PM   #10
Syroyizhka
Syroyizhka's Avatar
yes it is. my clutch is fine for now, but i like to do some hardcore accelerating though... now that i look back, i wonder how much damage i've caused :)
Tags
clutch slips
07 clutch burning? driver or design? kennywhy DIY / Maintenance / Service 22 10-01-2009 02:03 AM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 02:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
Street/Race Clutch dngz Performance Modifications 10 06-23-2007 01:05 PM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 11:08 AM
