Old 10-30-2008, 03:44 AM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
What temp to bake headlights?
Hi was wondering the temp and time you guys put your headlights in the oven before you pry them open. Also, i believe you put them back in the oven to reseal them. Correct? I will for sure reseal them with some silicone. Do I put silicone where the old sealant is and rebake to seal? or should i just try and reheat the old sealant squeeze it together one last time, then when cooled put silicone bead on the outside where the lens meets the housing.
I am hoping to take out the orange reflector this weekend.
*I'd like to hear the responses of people who've actually done it to their yaris headlights.
Thanks!
Old 10-30-2008, 05:00 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Why would you want to pry your headlights open?
Old 10-30-2008, 06:11 AM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i think i seen a thread somewhere around here on this let me go look
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 06:13 AM   #4
battleversiontc
here you go killa http://www.yarisworld.com/forums/sho...highlight=oven
Old 10-30-2008, 01:35 PM   #5
PETERPOOP
PETERPOOP's Avatar
ah thanks man.i'm a newb
Old 10-30-2008, 01:37 PM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
200-210 for 5-7 minutes should do it. If you are having trouble, leave them in there for around 10.
Old 10-30-2008, 01:41 PM   #7
PETERPOOP
PETERPOOP's Avatar
the link said not to leave them in there for 5-7 minutes straight. What am I suppose to do? Take it out every two minutes, let it cool for 10 seconds and then put it back in for the remaining time?
I guess I'll check the headlights every 3 minutes or so and try and pry it. if i can't, i'll put it in for another minute, then try and pry it again and repeat process until successfull.
i swear you are suppose to put the headlights back in the oven after you take them apart to reheat the existing seal. but that link didn't say to. he didn't even reseal the headlights with silicone though! So can I realllly trust him!? haha
Old 10-30-2008, 01:47 PM   #8
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
man the sealant that comes with the light is gonna be a pita to get back in place, i bought some sealant from autozone and replaced it
DMart is offline   Reply With Quote
Old 10-30-2008, 02:19 PM   #9
largeorangefont
Break'em off some.
I would get a friend and 2 hairdryers to reseal them. Each of you take a side and go around and heat the sealant, get it hot and push the halves back together.
Then I used Black RTV and run a bead of that around the seal after you are done just to make sure you cover any possible leaks.
Keep the oven as low as possible. It really depends on your oven, but just keep an eye on it.
Old 10-30-2008, 04:37 PM   #10
PETERPOOP
PETERPOOP's Avatar
thanks guys. appreciate it a lot!
Old 10-30-2008, 04:43 PM   #11
Lowest temp possible, you do not want to warp anything. I turned mine on to 300 then turned it off, let it sit for 10 minutes then popped them in the oven, laying them on a towel as to not melt anything. 5 minutes later it was ready to go.
Old 11-01-2008, 02:38 PM   #12
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
225 F for 5 minutes. Use a cookie sheet.
Pull off the old sealant and use this stuff:
Old 04-25-2009, 03:42 PM   #13
Carson
Drives: 2009 Liftback
I also want to try that. Where you able to get the reflector out.
Carson is offline   Reply With Quote
Old 04-25-2009, 04:00 PM   #14
PETERPOOP
PETERPOOP's Avatar
i never attempted it. sorry
Old 04-25-2009, 04:34 PM   #15
Carson
Well I'm heating up my oven now. I'll let you know how it works out.
Old 04-25-2009, 04:39 PM   #16
PETERPOOP
PETERPOOP's Avatar
haha. good luck! post pics. don't forget to reseal them!
Old 04-25-2009, 06:08 PM   #17
Carson
Well that was relatively painless the only hiccup was that my small apartment size oven was too small for me to close with the headlight in it.
I set my oven to 275 but i would recommend closer to 220 if you can get the oven door shut. I left it in for almost ten minutes and I put the headlight on a wet dishtowel on a baking sheet to keep the plastic from melting.
As you can see from the pictures after you remove the reflector there is a hole visible where the side marker light comes through. I'm not sure how it will look at night. I'm thinking of painting the reflector black or silver and then re-installing it. What do you think?
Old 04-25-2009, 06:13 PM   #18
PETERPOOP
PETERPOOP's Avatar
good job!
Well If you don't like the bulb, you could always take it out. What is that bulb called? Is that the city light bulb or something. Is it just a plain color bulb? I would say take it out. Might look weird at night.
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
temp gauge? gaf99 General Yaris / Vitz Discussion 10 01-15-2007 10:43 PM
Auto dim mirror with compass and temp Violin Cosmetic Modifications (Exterior/Interior) 7 08-30-2006 06:48 PM
WTB: Yaris Liftback Taillights and Headlights TRD_Yaris Items for Sale by private party 9 07-24-2006 03:44 AM
