![]() Drives: Sedan Join Date: Feb 2009
Need Help Figuring this out
Ok so today, I was at the local audio store looking at some stuff and when i went to my car the door opened with the auto key and then when i go to start the ignition, car wont start! I wait 2 minutes and nothing still. The only thing i have hooked up to my battery is a 200 Watt amp. I went and unhooked the amp and the car started! What could be going on? The amp is wired so that it only turns on when the head unit turns on and im using an 8 guage wire to hook it up from the + end of the battery to the amp
Any ideas |
double check your grounds.. did you fuse the power wire going to the amp?
Ya there is a 60A fuse running close to the battery and the ground is connected to a screw i found in my trunk
Y4R1Z
Did you sand the area around that screw for the ground? May not be getting good contact if there's paint in the way.
I believe it is grounded properly cause this only happened twice so far and the amp has been in there for 4 months
would it be possible that water was touching the positive part of the battery and shorting it out?
Y4R1Z
maybe... i'm not really sure about that though. It would have to be enough water to allow the positive and negative sides to touch... i think.
ok so it happened again today except i actually needed a boost to get it started and then when i shut it off i needed another boost! Im starting to think i need a new battery? What do u think any suggestions on a specific type
i think you need a new battery or alt not working so good
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
Roadrunner Jr.
Take the fuse out of the power line on the amplifier so that it doesn't turn on. If you're at an audio shop, they should have a battery charger hanging around somewhere. What I'd do is to ask them to hook up the car's battery and charge it for a while. Now, if you take the car off the charger and it dies after a little while AFTER YOU ARE ABLE TO TURN THE ENGINE OVER...you'll probably notice that you have a nasty rough idle...your alternator is dead.
The dealership SHOULD be able to replace the alternator under warranty. Just make sure they know that the sound system is fused and grounded properly so they can't bite you in the a$$ saying that it was the system that caused the alternator failiure. I honestly can't see a Toyota dealer doing that the first time you bring it in though.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#11 | |
Y4R1Z
![]() Sorry... not tryin to hijack the thread! *climbs down off soap box* |
Y4R1Z
do what sqcomp said though, I think he's got the right idea.
Roadrunner Jr.
That $ucks to hear about the dealership! You should run the car through the front window of the dealership and start taking hostages!
Juuuuuuuuuuusst kidding.
#14 |
Y4R1Z
#15 |
Roadrunner Jr.
hey Canadian...
What is the fuse rating on the amplifier? Aside from that it really sounds like your alternator quit on you.
