Old 05-01-2009, 04:46 PM   #1
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump?
If the Yaris can handle the 6psi of boost, i will be able to build the cheapest and simplest supercharger kit on the market today and be able to sell it to anyone who wants one. if it's just a matter of upgrading the fuel pump and using some slightly bigger injectors and letting the ECU do the rest. then i think i could really pull this off. the kit would comprise of a supercharger(duh!), an intake pipe from the supercharger to the throttle body, a BOV on the intake pipe and maybe bigger injectors and fuel pump(depending on the Yaris responds to 6psi stock). so, please let me know what you guys think.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 05-01-2009, 04:55 PM   #2
33OH
Drives: '08 Yaris
From what I've read on the Forced Induction forum; the stock fuel pump will definitely work and stock injectors should work as well. But I am by no means any sort of expert on the subject.
But I would be interested, depending on price, if it works. =)
Old 05-02-2009, 05:57 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
+1 stock pump/injectors should handle 6 psi. Just need a piggyback for the ECU.
Old 05-03-2009, 12:35 AM   #4
Blitz supercharger blows 7 psi with stock injectors and fuel system. I ran an 8psi turbo set up with Scion tC injectors and stock fuel system otherwise.
Old 05-03-2009, 03:45 PM   #5
gwasabi
Drives: 07 Blazing Blue LB
sorry to thread jack but just a quick question. Can the yaris ecu handle a 5-6 psi with no piggyback?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-03-2009, 03:55 PM   #6
Garm can answer that best, I believe he ran his car prior to this with 8psi on stock electronics with just bigger injectors.. Gave a couple CELs of course, but with lower boost you *may* be able to get away with it
Old 05-03-2009, 04:03 PM   #7
gwasabi
I was planning to build a turbo kit but I don't want to bother with a piggyback management for now so I was planning to run a low boost for a while just to get the kit started.
Serious Business...
Old 05-03-2009, 04:14 PM   #8
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Ughhhh since no one asked this yet.... What model supercharger, how do you plan on using a BOV and why would you need one? You're leaving alot to imagination and I hope you can provide some solid good answers! :)
I've been planning on making a turbo kit for a while, but it's been all talk and research research research until I'm starting to pull a few strings and get things together with my business.
Old 05-03-2009, 04:32 PM   #9
gwasabi
Honestly, I still think the Power Enterprise Supercharger kit is still the best one I've seen so far. far better than the blitz. This is only from videos I've seen from japan.
Serious Business...
Old 05-04-2009, 07:08 PM   #10
PHXDEMON
PHXDEMON's Avatar
Speaking of which didn't someone on here get that kit? i think it was frownonfun or something like that.
Old 05-04-2009, 09:26 PM   #11
Nexus1155
Drives: Audi
yeah and then never updated anyone or anything and then Power Enterprise Evan went off the face of this earth... sounds like something shady went down to me!!! Hope someone knows if the guy(s) are okay
Old 05-05-2009, 08:04 AM   #12
33OH
Drives: '08 Yaris
frownonfun got it finally, hes been working on translating the instructions from Japanese to English last I heard.
Old 05-05-2009, 08:22 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
i don't see how a centrifugal supercharger is "better" than a positive displacement SC.. but to each their own.
Old 05-05-2009, 09:12 AM   #14
Nexus1155
Drives: Audi
I don't see why you would need to translate instructions from Japanese to English if its just like 10 parts... couple pipes, bracket, supercharger, what else?
Old 05-05-2009, 09:40 AM   #15
33OH
Drives: '08 Yaris
http://www.yarisworld.com/forums/showthread.php?t=16426
Old 05-06-2009, 12:14 AM   #16
trini_per4mance
I'd like to tell you what model supercharger, but I won't. All I can tell you about the supercharger I have in mind, it's a maintenance-free unit. No oil required. The BOV will be located on the one and only piping that goes from the supercharger to the throttle body. I would use a BOV to prevent any boost from putting a strain on the impeller and for those who love the sound. I'm looking to run as much boost as possible with as little mods as possible.
Old 05-06-2009, 08:20 AM   #17
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
call me ignorant, but i've never heard a SC using a bov, wouldn't that defeat the purpose of the SC?
Old 05-06-2009, 08:26 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
superchargers generally use bypass valves or butterfly valves. i wouldn't a BOV on a stock ecu'd car, especially if the bov is located between the MAF and throttlebody. you aren't delivering metered air to the engine, it's being vented to atmosphere.
Another S/C'd member worried about his AFR LtNoogie Forced Induction Forum 181 04-18-2009 12:19 AM
Any body have good data on the Yaris fuel system? LtNoogie Performance Modifications 9 03-26-2009 08:01 AM
