Old 03-14-2007, 09:29 PM   #1
ChinoCharles
Drives: LB
1NZ port & polish
Ah, the famed port and polish. It is usually a step taken towards the end, but lets assume for a second I had this done on my car right now.
Forget about price... don't sit here and say how the expense isn't worth the gains. A port and polish can run over a thousand dollars alone... this isn't something a lot of people will end up doing to a 1NZ.
My question is assuming a 1NZ was ported, what would happen? I know literally nothing about this... its supposed to net gains, and likely more with a tune like any part. What I am wondering is what do you have to worry about when tuning a car with a P&P? What will happen to timing, air/fuel, engine temps, horsepower... give me (us) an idea.
Old 03-14-2007, 10:26 PM   #2
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
i think it depends upon what your port and polishing. most common is the intake manifold and that seems to be a problem for us lol. next is your throttle body but then you need a larger butterfly. those are the only 2 i know of....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 03-14-2007, 10:36 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
If you did a port and polish to your car as it sits now, the results would be less dramatic than adding a lightened crank pulley.
For all intents and purposes, the intake is already done, as it is smooth plastic. Cleaning the throttle body up, gasket matching the intake and exhaust, cleaning up the ports and doing a bowl blend won't net you too much. Definately less than 5 HP.
Old 03-14-2007, 10:39 PM   #4
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
Think about it this way - what gains do you get by freeing up flow with an intake or exhaust? A PP job will have the same sort of effect as it's also just about increasing air flow as well.
Bottom line is it'll kill your low down torque, but increase HP at high RPM.
The question is: is it really worthwhile? I mean the 1NZ-FE bottom-end is not designed to be a high revving powerhouse, in fact it's optimized to be pretty much the opposite. So tweaking/tuning this engine for high RPM performance (with a stock bottom end) will quickly get to the point of little to no net gains IMHO.
Now if you're thinking about forced induction and rebuliding the bottom end, that's a different story! But I would definately be working on these before I'd even consider a PP job.
Many moons ago I was getting 200WHP from a Mazda B6 1.6L Turbo with 15PSI boost, a monster air-air intercooler, a 3" dump pipe through a cat-less system, and a 6" cold-air intake.. Porting and Polishing the heads and putting in custom grind cams (all done by a local rally team that ran the same car) lifted that to 242WHP, so a good 20% gain. BUT you'll notice that it was the last step taken - had this been done before any of the other mods it would have been a WOFTAM.
Razr is offline   Reply With Quote
Old 03-15-2007, 12:35 AM   #5
Good reading:
http://www.scionlife.com/forums/viewtopic.php?t=67782
Old 03-15-2007, 02:48 AM   #6
Razr
YRS WHOR
Razr's Avatar
That was a really good read in fact - thanks!
Kinda confirms everything I've learnt from anecdotal reports with some hard facts for a change. Too bad you have to sift through all the replies to get to the meaty bits though - a blog would've been awesome.
If you're thinking about tweaking out your Yaris, reading that thread is a must!
Old 03-15-2007, 01:00 AM   #7
ChinoCharles
Drives: LB
That thread is legendary. Bet your ass I've seen it before. He made one huge mistake... that Camcon.
Bottom line, if you could have your heads ported for free, would you take it? Yes or no.
I'm not asking your warranty. I'm asking you.
Old 03-15-2007, 04:58 AM   #8
who could refuse a free head job?
Old 03-15-2007, 05:03 AM   #9
Razr
YRS WHOR
Razr's Avatar
Well, there's a few girls I've seen who might give you second thoughts about that I'm pretty sure it's free too
Old 03-15-2007, 05:07 AM   #10
Isn't that what paper bags were invented for?
(it's official, I am going to Hell, or will be reborn as a cockroach)
Old 03-15-2007, 02:12 AM   #11
Razr
YRS WHOR
Razr's Avatar
Free? sure, then I'd Ebay 'em :)
Old 03-15-2007, 02:36 AM   #12
Razr
YRS WHOR
Razr's Avatar
Let me clarify that a little.. I'd Ebay them and put the money into the "2ZZ-GE engine swap fund".
From everything I've learnt about this engine in the past 2+ years (my last car was a 1NZ-FE as well), it takes mega bucks to make minimal gains.
Our resident sticker guy and all-round good fella eTiMaGo tells me we can get 2ZZ-GE's retrofitted into our Yarii by TRD Thailand for ~100K Baht (USD $2850). Given that the 2ZZ-GE makes 180HP stock, by the time it's in a Yaris with a custom mandrel bent exhaust and intake we should be looking at 200+HP.
There's nothing you can do to a 1NZ-FE for that money that would get remotely close, plus you've got the headroom for forced induction and other mods (if your mother dropped you on your head as a baby, and 200HP in a tiny FWD egg isn't enough)
Anyways, you can see where my thoughts are at
If I could get 4WD and a DSG box to go with a 2ZZ-GE for this thing, I'd order it all tomorrow - along with some blowage, 'cause that'd be a fuckin fun car.
Old 03-15-2007, 05:05 AM   #13
Amen... You could get the transmission and AWD system off an older Celica GT Four, though I have no idea if it'll mate to a 2ZZ... so how about a 3S-GTE Yaris?
Old 03-15-2007, 05:34 AM   #14
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
They do have a 4WD 1.3 litre NCP91 Vitz in Japan, though I have no idea how you will get your hands on it. There's all your needed bits right there.
cleong is offline   Reply With Quote
Old 02-07-2009, 10:10 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
i'm making 155whp and 150wtq and i spent around 1200 out of pocket..
that's more torque than a 2ZZGE makes, and not far off in WHP at the wheels..
you can't touch a 2ZZ + swap labor for 1200
Old 03-15-2007, 06:00 AM   #16
Razr
YRS WHOR
Razr's Avatar
Could have difficulties lining up a decent 3S-GTE these days, AFAIK they've been out of production for 8+ years now? been a while since Ive seen a GT-4 or MR2, so could be wrong :)
I was thinking more along the lines of the 4WD system from the 1.3L JDM model, and of course DSG is just a pipe dream - the only Jap brand I know of that's even hinted at one is Honda in the concept/proposed 5dr Civic Type-R :(
Old 02-08-2009, 01:59 AM   #17
Midon
Mod Freak
Drives: 88 MR2 GT
Just a little info on the 3S-GTE. They can still be purchased from Jasper. I bought one not to log ago to replace in my MR2 that had 260k miles on it and fired piston rings. I did this when I bought the car and spent 5,000 USD on every thing. Oh and I payed 100 bucks for the car hehehe.
Midon is offline   Reply With Quote
Old 03-15-2007, 06:01 AM   #18
Razr
YRS WHOR
Razr's Avatar
snap! err.. wtf :(
What type of head unit with AUX port? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 3 11-06-2006 10:21 AM
ODB-II port location? eTiMaGo DIY / Maintenance / Service 6 09-24-2006 12:27 PM
Port A Walls tomjasz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 09-04-2006 04:20 PM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
