Give Me Resonance
Ok so I got HIDs in today (as shown below) theyve got a ground and a power wire. i put the wires in the headlight harness, the ground went into the slot that it did because the other slot had no effect at all (as illustrated below) and turned on the lights and the bulb flickers then turns off. I figure....DRLs need to be removed. I find the DRL removal official thread and search underneath my steering wheel and all around for a half hour with no luck... If I dont have a DRL Module for some reason then why are my HID's flickering? HELP ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() THIS IS WHERE THE TUTORIAL SHOWS IT BEING ![]()
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
I'm sure you searched very thoroughly, but the DRL module is hidden REALLY well. It took me a really long time to find it (and an even longer time to pull it out...)
Do you have the convenience/cold weather package? |
Give Me Resonance
I dont think that I do, to be honest Idk, I think i resolved the HID flickering problem but im still curious as to where the module is at if I even have one.
that picture of the DRL module is of it taken out of its bracket.....i left mine up there and just unplugged the harness for it. i think i can see the wiring for it on the right of your last pic....its really tucked up and to the right....and its a biotch to get unplugged too (esp if you have bigger hands)
youll want that DRL module off before you fry your ballasts... i also see you didnt buy bi-xenon HID's....looks like youll be w/o high beams...
Give Me Resonance
i got them installed and working fine without any flickering or anything, didnt get the drl module out, my headlights are the depo projectors and yes im w/o high beams but theyre so bright it doesnt really matter, i never use highs anyways.
Hey architect how did you solved your bulb flickering problem??? I didn't find the drl's too.
| DRL Questions. | AznGouki | Cosmetic Modifications (Exterior/Interior) | 14 | 10-28-2008 03:07 PM |
| DRL disalbled. | IllusionX | DIY / Maintenance / Service | 0 | 10-22-2008 03:16 PM |
| DRL enabled with HIDs... sort of... | Galavoxx | Cosmetic Modifications (Exterior/Interior) | 0 | 03-28-2007 08:26 PM |
| Using parking light as DRL? | GabL | DIY / Maintenance / Service | 6 | 11-11-2006 09:31 AM |
| NO DRL ???? | argylesocks | DIY / Maintenance / Service | 8 | 08-12-2006 08:24 PM |
