l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
Widest Possible on Stock Body Yaris
Hey guys,
I'm looking to do some nice wide wheels on our Yaris. I'm thinking 15x9. Thoughts? |
Break'em off some.
Go ahead. They will stick out.
l33t3st Asshole
I'll help an xA owner setup some 15x9s then test fit them.
haha. I saw a set of 18x8 +40mm's on Tire rack with a 215/35/18, if Tire Rack lists it that means alot. I'm curious if they screwed that up though. some 15x8s would be pretty nice. although i have a feeling they'd still poke. I should just stick to my original plan of 16x7 +38mm front +28mm rear. gotta find an xA owner who needs 15x9s and convince him to buy new wheels.....
#4 | |
Break'em off some.
Anything more than 7.5 in the front will poke in the front. My 16X7+40s are flush in the front |
#5 | |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
a 235 is the smallest width that will fit on an 8" rim. not even close. i have 275/40/17 on my camaros. u'll be lookin like the old school mexican's cars with the reverse offset rims on the small cars like hondas n mustangs....from the early 90's. and really....i think a 6" width would be more than enough to set the tire edge even wit the fender....which will still be legal for street. |
Break'em off some.
No that is not the smallest for a 235. It will look OK. You can run a 235/40 on a 9 in wheel with no problem, and it is within the manufacturers recommended limits. A 215 on an 8 is ok as well, just at the small end of the spectrum.
#7 | ||
l33t3st Asshole
we're running 10mm hub spacers in the rear and it's really flush, but we have a large amount of inboard room. if we did a wider wheel I know we'd need to do a shorter tire. I guess I need to really just take some more measurements, I'd rather not run a wider wheel in the rear just for looks. I need to host the new snapshots we got with the Tamago Hub Spacers on. just curious what the other Yaris guys thought, thanks Orange. Quote:
when you "smallest width" where are you getting your info? |
The widest wheel I've ever seen run on a Yaris is a 15x8, FWIW.
l33t3st Asshole
yeah, we're lacking some wheel well in the front to really push it further.
The only way you're going to shove a 9+ inch wide wheel under this thing is to either go with some fender flares or a widebody kit and run some stupid offset, which I'm all for by the way.
#11 | |
l33t3st Asshole
i've got a set of over fenders that would work on the yaris pretty well. but they are for the rear, where we don't really have the problem of space. |
Do it to it. I'd like to see.
l33t3st Asshole
which part?
mocking up the rear flares or cutting up my girlfriends yaris?
Both!
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
you could fit 8" side rims with a 40 offset in I have 42 offset on 7.5" side rims and they fit fine.with my drop they rub on some bumps on the inner plastic wheel well,so you could do 8" but you gotta find light rims and right profile tires....or poor car will be slow as slow can get.
l33t3st Asshole
still on stock struts?
toyota
like this.
l33t3st Asshole
:vomit:
did you read the title? read comprehension owns. |
| 05 AU Yaris Stock Speakers + Alpine iDA-X001 | thatfilthyspringbok | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 09-10-2007 09:06 AM |
| Yaris Body Kit Available in US - SEMA Yaris | DJFMedia | Cosmetic Modifications (Exterior/Interior) | 26 | 10-21-2006 03:00 PM |
