![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
Interior center console switch cutouts?
Oay Im sorry for the crude Title, but there are same size cutout located next to where you switch the interior light dimmer (this is also one of them), or by your emergency brake. These appear to be a standard size idustry standard item, and I was wondering I would loked to utilize some of the blank ones with a lighted switch lite when on, for activating a low power item.
Is there a source that I can buy switched or other type items that are pop in replacement size wise to these? I could take the blank out and put a switch into it, but I think I would like to keep the blanks if I sell the car down the road, can anyone tell me what these are called or a source for replacements that have a custom application in mind? Thanks, Ron |
Im still looking for information on this?
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Dude I can't understand your post.........
in short, he wants a switch that fits right into the blanks by the handbrake.
and no, they do not seem industry standard. They are more like TOYOTA specific. |
Thanks IllusionX for your comment, I could probably just order some blanks from toyota and drummel a switch into them, thanks so much. Ron
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
Yeah I've put things in those spots before. You can fit most standard switches in them with a little work. Good luck and post up what you do.
Tantum religio potuit suadere malorum. |
^ thats what I did for the toggle for my aftermarket fogs, just take the blank out, cut out the size hole you need, and plug it back in.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
