Old 06-17-2009, 03:15 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Intake to match the 1ZZ throttle body
most of you that are using the 1ZZ throttle body already realize there are two issues which could be potentially not allowing the TB to achieve it's maximum potential.
The first is the intake manifold does not match the throttle body and the intake s most people are using are slightly too small. My measurements show the old intake tubing diameter to be 2.25"(I am using a Bomz) and the new intake inner diameter is just about 2.5".
I know there are those who are stating a slightly larger intake will throw a cell. Is there anyway around this such as a different sensor - lets say from a Matrix or a Corolla just like the throttle body chip swap.
It is not that big of an increase in diameter but it may yield some gains and should be relatively easy to fabricate.
What do you guys think? Is a sensor swap even possible? Would it make a difference? If it does lean out, how about just adding some bigger 1ZZ injectors. Mixing and matching parts is great. Makes me feel like Dr. Frankenstein or the weird doctor from Robot Chicken
fuji is offline   Reply With Quote
Old 06-17-2009, 09:41 PM   #2
fuji
fuji's Avatar
Anyone?
Old 06-17-2009, 10:02 PM   #3
robot chicken, lol. I think you cannot just swap sensors if you mean the MAF sensor. Your ECU wouldn't know what to do with the signal. Probably won't be the same size either, so you'd be custom fabricating just to find out if it works.
Port match the intake mani first, it's easier and probably will have a positive effect.
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
