Old 03-07-2009, 04:59 AM   #1
abdallah380
Fly Emirates :)
abdallah380's Avatar
Drives: 2010 Yaris Sedan
interior led...
hey ppl, i want to get those cool led lights (dont know what they're called) that is placed below near the pedals and the other one where the passenger is seated. they are turned on when u put on the headlights... i just want to know how are they fixed? or attached... thanks
abdallah380 is offline   Reply With Quote
Old 03-07-2009, 09:31 AM   #2
The easiest way is to use strips that have mounting holes or adhesive backing. Here's a place where I buy a lot of LED fixtures from:
http://www.superbrightleds.com/light_bars.htm
Old 03-07-2009, 10:19 AM   #3
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
I will be doing something similar to my Yaris soon. This is my wifes 2008 xB:
I will be doing Red in my Black Sand Pearl Sedan......
I used the following kit:
http://www.ledunderbody.com/led_inte...underdash.aspx
Blue_dragon_192 is offline   Reply With Quote
Old 03-07-2009, 04:26 PM   #4
abdallah380
Fly Emirates :)
it looks really cool on the xb....
is it possible to attach those leds without actually having to make any holes in my car?
Old 03-07-2009, 04:29 PM   #5
abdallah380
Fly Emirates :)
i want a red leds too for my barcelona red sedan.... blue has gotten a bit too common i guess.
Old 03-07-2009, 04:44 PM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^You wont have to drill holes if you use the adhesive backing, and for the switch you can use one of the breakout switch plates, assuming you have some left.
Old 03-07-2009, 05:56 PM   #7
Blue_dragon_192
The best way to mount the LED's is to use the clips that come with the kit, line them up and make sure they fit properly first. Then clean the area with the wipes that come with the kit.
I then added tie-wraps to hold the clips in place, just in case.
With the seats being similar to the XB, this is easy. Just mount the LED's under the seats using one the the bars under the seat (like the bar that allows the seats to move forward and back).
Old 03-07-2009, 08:45 PM   #8
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i have some pre wired LED (led with resistor for LED) I might have some more of the stainless steel mounting rings for them too.. you'll just have wire them up and wire them to a 12vsource (put a switch inline if you want to be able to shut them off)
send me like $5 total for the pieces and shipping .. i will send 4 of the pre wired led and the 4 mounts if i have them
I did one on each foot well and one below each seat and its perfect. Not wicked bright like on that xb its a good brightness that isnt distracting when driving
Old 06-19-2009, 05:39 PM   #9
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Just want to clarify on this stuff since I'm just getting the hang of how things work when wired into cars. If I wire the power directly to the battery, whatever I have wired (LED's for example), will shut off when the ignition is off?
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 06-19-2009, 08:02 PM   #10
The battery is a constant "on" source, so you need to connect to a power source that is switched by the ignition. Tapping into the power to the lighter outlet is an easy switched source.
Old 06-19-2009, 07:09 PM   #11
pixitha
Pixitha
BlueDragon: what did you connect the power to on the xB you wired up with that kit?
pixitha is offline   Reply With Quote
Old 06-19-2009, 08:04 PM   #12
nick.dollimount
Yaris = <3
That wouldn't put too much strain on it and blow a fuse, would it? I guess I've had several things plugged into my lighter at once and it was alright...
..:'; Nick ;':..
Old 06-19-2009, 08:16 PM   #13
The lighter is on a 15A fused circuit. You could run many strings of LEDs off that.
Old 06-19-2009, 08:17 PM   #14
nick.dollimount
Yaris = <3
And still have my blackberry plugged in to charge?
..:'; Nick ;':..
Old 06-19-2009, 08:54 PM   #15
Sure. A phone charger is really a low current device. You might be pushing it if you had 20 strings of lights and an inverter powering a laptop's AC charger.
Old 06-19-2009, 08:43 PM   #16
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i went with Cold cathodes from oznium, great price, especially if you are not in instate no taxes! I matched the stock amber dash colors well.
