What filament does the DL running light use?
Since the Yaris use a double filament headlight bulb, (a single bulb for both low and hight beam) I'm curious about which filement the DLRL uses.
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
i will look on the EWD and make sure but i am 95% sure that it uses the high filament... give me a couple minutes...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
uses low beam in Canada. Pretty sure it is the same in the States.
Most cars use the high beam at lower voltage for DLRL.
I assume that the Yaris does the same but, i just wanted a definitive answer. I guess I will still have to wait on this.
#5 | |
2. turn on vehicle. 3. look to see which filament is lit ;) heheeh sorry man, it just appeared to be the most definitive solution.
![]() Drives: 2009 Yaris w/man.trans. Join Date: May 2009
On my 2009 daytime running ligts use a separate smaller bulb located apart from the primary bulb - very clever and efficient set-up. Or am is not getting the question?
i think you're referring to the 'city light' the 194 bulb.
#8 | |
try removing the bulb on the passenger side?
From the 09 service manual:
(2) The Running light relay assembly controls the on/off operation of the following part. • Headlight (Low)
Thanks
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Day time Running light....how to disable? | Polar_Yaris | DIY / Maintenance / Service | 33 | 01-27-2009 06:02 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
