Old 05-31-2009, 04:35 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
1ZZ Throttle+Bomz intake=Power!
I installed the throttle body I got from Garm. Instead of the stock intake, I used a Bomz intake - I just could note get the stock rubber intake tube over the new throttle body. The Bomz silcone intake adapter was a breeze. Install was not very hard at all - just a pain in the ass to get to the wheel well to get the filter on. While I was down there, I decided to pop out the black plastic insert where the fog light goes just to see if a bit more cold air will make a difference.
Wow! Power/torque in the whole PM range with the most prominent gain in the mid and upper ranges. I had only a bit of mild oscillation on the initial start up and no problems since. For the price, this is a MUST mod.
Interestingly my exhaust sounds louder. It is not coming from the front as I expected.
Just make sure you follow all the instructions on the website, gasket sealer is a good idea, disconnect the battery for a while(only did mine for 30 min and left the light switch on)
I will modify the L foglight plastic insert into something more cosmetically pleasing. I will also change the silicon to black and paint the intake tube flat black.
:burnrubbe r:
fuji is offline   Reply With Quote
Old 05-31-2009, 05:06 PM   #2
gwasabi
Drives: 07 Blazing Blue LB
hey brian, I actually got an idea for that foglight cover. Remember I told you I was trying to work on something for it? well I think I got it figured out. After I actually do the process I'll let you see it maybe at the meet or something.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-31-2009, 05:16 PM   #3
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
looking good
808_Yaris is offline   Reply With Quote
Old 05-31-2009, 10:06 PM   #4
Taiyaki
アキバ製
Taiyaki's Avatar
very nice thinking about doing this after I pick up your springs and exhaust. ;)
Old 05-31-2009, 10:28 PM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I dont know what the hell my issue was, but with this EXACT combination of TB (chip swap) and intake, I could NOT get it to idle at all, and throttle response was non-existant.
Im thinking about starting again with the throttle body from garm, as I dont know if mine was damaged or what.
Old 05-31-2009, 10:41 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
^ it wasnt damaged. well at least for 2 days i didnt feel anything besides the retarded oscillation. i took it off again though because i needed to finish off cleaning the gasket thing from the tb, then hopefully i would put it back on int time for the rockland show, if work permits.
Old 06-01-2009, 10:49 AM   #7
AlexNet0
AlexNet0's Avatar
^ what I got wasnt the 2-3k rpm oscillation that others got, I got 4-5k oscillation and the chip swap made no difference, however I do not believe I had a good seal on the Tb and intake mani
Old 06-01-2009, 07:23 PM   #8
fuji
fuji's Avatar
The other thing I have noticed is much quicker throttle response. I am glad I never got a Blitz Throttle controller!
Old 06-26-2009, 01:51 PM   #9
2bad4u
Drives: 06 Toyota Vitz RS
I have been think about the two mods trying to decide on which to do, but on your note it will be the tb swap. thanks
2bad4u is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 08:57 AM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
1ZZ throttle - Not Optimized Yet! fuji Performance Modifications 30 06-04-2009 01:40 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
