Old 01-06-2014, 11:54 AM   #1
Josepe-sv
Drives: Yaris 2008 HB 1.5
Car battery 12V 75AH
Hello, I've been using a 12 V 75 AH batt (first and second)
Now I'm replacing the second battery, the new (third) is 12V 55 AH (there is no 75 AH actually in store)
At the fisrt milles the car looks like loosing power (by aceleration keeps power on). Now after running 15 milles the car works fine.
Is enought the 12V 55AH or should replace for 75AH?
This is a Yaris HB 2008 1.5
Josepe-sv is offline   Reply With Quote
Old 01-06-2014, 12:12 PM   #2
The original Toyota battery is only a 45 Ah battery, so the 55 Ah is sufficient. The question is why are you going through batteries so quickly?
Old 01-06-2014, 05:12 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
The constant heat in central america sure is a killer to car batteries.
Old 01-06-2014, 06:13 PM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Maybe the alternator had a lot to charge ;)
Power doesn't come out of nowhere^^
dj92 is offline   Reply With Quote
Old 01-09-2014, 07:14 PM   #5
Josepe-sv
In this country the batts life average is 2 years (some months more). I was using 75 ah because the car comes with 75 ah, but now I have been using the 55 ah for 4 days and works fine. Thanks for the replies.
Old 01-10-2014, 04:33 PM   #6
captainm27
Drives: 2008 Sedan A/T Silver
The same thing happened to me. After 5 and 1/2 years, I replaced my car battery with a new one. The first few miles, my engine was idling so close to 500 that I thought it was going to stall. As I was driving, the RPM would drop really low as soon as I came to a stop. After 15 minutes, it returned to normal. I was almost going to return the new battery.
captainm27 is offline   Reply With Quote
Old 01-10-2014, 08:41 PM   #7
nookandcrannycar
A somewhat similar thing first happened to me when I replaced my OEM battery. I posted my concern. CTScott posted to give it a few more miles because the ECM needs to relearn the fuel trims. Sure enough, after a few more miles everything was fine.
Old 01-14-2014, 12:59 PM   #8
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
I think the key is an AGM type battery.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 01-14-2014, 01:12 PM   #9
bermuda boyd
Drives: yaris verso 2001
afternoon all
battery incorrectly installed thus issues with fuses
short:
Took a plane trip, battery down on return
charged battery
put in backwards - and + (yes i know) was that kind of a day
saw sparks so stopped and found no response from victim (car)
researched here and elsewhere
found a 'fusible link' wire at a wreckers which he gave me
nice guy
replaced it and the 15 A "dome" fuse
car works great
only radio, light and clock are off
any suggestions?
many thanks for the help
will review all the other fuses as well first while waiting
happy new year 2013 all
Boyd
bermuda boyd is offline   Reply With Quote
Old 01-14-2014, 01:14 PM   #10
bermuda boyd
15 Amp fuse 'blew' 2 more times
Old 01-14-2014, 02:16 PM   #11
The Yaris does not have any significant reverse voltage protection, so you can do some serious damage connecting a battery backwards.
To start with, disconnect the two ECM (engine computer) connectors and see if DOME fuse still blows. If it does not, then you may have damaged the ECM (which is the most sensitive device to reverse voltage).
Old 01-14-2014, 03:20 PM   #12
IllusionX
oh and there are reverse polarity batteries out there... just beware when you buy it.
Tags
battery
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 05:43 PM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 11:02 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 07:02 PM
