Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Hatch/Liftback Owners with AMPs - Where did you connect the ground?
I would like to know where the best areas are for the ground connection for an amplifier in the rear area of the Hatchback/Liftback, particularly in the spare tire well and trunk area.
Can anyone offer some help before I run off to RadioShack for a voltmeter?
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris sedan Join Date: Aug 2006
Right Under the backseat. One of the bolts that hold the seat and set up down should work great.
Cousin Vitz
Thanks nick, but I'm not sure if I can locate those bolts.
Do I need to remove the seat bottom (mine's a hatchback) to expose those bolts?
Cousin Vitz
I've attached two photos here for potential grounding points:
Spare Tire area - 6 Points Seat Belt lower bolt - 2 Points (left/right) What do you think? PS - Thank you Idjit for taking these pictures.
#5 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
how did you do that? How do you remove the rear seat from the frame like that last pic
The early bird gets the worm, but the second mouse gets the cheese. |
Cousin Vitz
The rear seat is not lifted up in the 2nd picture.
According to Idjit, the rear seat bottom was removed by disengaging two clips on the bottom of it that held it to the frame.
![]() ![]() Drives: 07 yaris 5spd sdn Join Date: Aug 2006
bigsky2,
Any factory bolt will do the trick; just make sure that the ring terminal is touching the chassis metal. If necessary, don't be afraid to scrape a little paint off. |
HardlyDangerous
I agree
grind, scrape or sand away any paint between the ground and the metal chasis. I would also add a dab of dielectric grease to keep it corrosion/rust free. Bigsky2 thanks I did not realize that. The RS has a different set up with the flat folding seats I guess.
#9 | |
#10 | |
Cousin Vitz
Yes, I will definitely grind and sand down the area I'm going to ground to. Thanks for the advice.
#11 | |
Cousin Vitz
I'm only going to select one ground point, as I'm grounding everything to a single point to prevent any new electrical paths to form, which could distort. Just needs some sanding and it should be good to go.
