![]() Drives: sw20 turbo Join Date: Jun 2006
look at what i did
tell me what you guy and or gal think??
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I know you worked hard on this, and I commend you for that, but it looks really ghetto.
The plastic on the amp looks like a Jerry Curl couch cover, the carpet incisions are glaringly obvious, you did no cable hiding or management except two wraps of electrical tape, and your Dynamat was obviously a very quick job, with no effort spent on reaching the edges of the space it is meant to aid. If a shop did this to my stuff I would demand a full refund and never come back.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
What's this meant to be? Was this a prank on someone's car?
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
did someone forget to unwrap that amp when they unboxed it?????
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
I dont think they forgot to take it apart...
wanted to keep the amp clean? that will just keep the amp hotter if you dont take it off dude. -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
SPONSORED BY
![]() ![]() ![]() ![]() ![]() Drives: 07 Bayou Blue Liftback Join Date: Apr 2007
The amp isn't even mounted people. I think he was just trying to illustrate what his intentions are.
BTW, it looks like you are putting together a nice system dude. |
oh ya your right....i dont see any screws...
but take that plastic off and its okay if ur 2 lazy to get the corners...i wouldn't too lol unelss u have extras. nice set up -- Blen
Lonesome Cowboy
yeah, blacksan is probably right
this is just "so far" pics, he'll finish it out
SPONSORED BY
yeah you guys are right. i have not finish the install yet. so far i have installed infinty 6.5 2 way coxial in the rear, rockford 4ch amp, 4awg wire, infinty 6.5 componet front spekers, all the spekers are in 2 ohms i dynomited the rear spekers, add the dei 530t window mod. and hooked up to the key switch. and i have the original radio with high lows. i did cut or slice any of the factory wires i just got a front and revers oem harness. and as for the bag on the amp, it came with the amp and i took it off after the install. also the amp is locade under the front pasenger seat. as for the big hole on the carpet, it was there arighty, if you open it up theres some numbers and letters. and i didn't mount the amp cause im not doun tunning it jet. the extra thing i would like is a rockford 1000 rms mono amp under the driver seat. 2 alpine 10' or 12' type-r, and a 2 frad cap. and mybe a new radio. oh and thanks for the replys
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Silly me... because I was thinking, with the Dynamat Xtreme, is it really necessary to cover every edge? Won't the amount shown in the picture add enough mass to alter the resonance frequency of the panel, and thus achieve the same as covering everything? Btw... I have never installed anything ever.
![]() ![]() Drives: 07 Bitchin Blue HB Join Date: Jul 2007
Take your time and keep things nice and clean. That amp needs to be rotated 180 degrees. The wires will be hidden and look better. The heat sink will be exposed as well, aiding in cooling. Have fun and dont get into the habit of "hooking things up real quick to see what it sounds like" Installations rarely get the finishing touches after that. Like I said have fun and take pics.
07 Yaris HB 07 Road King 06 Superduty CC 05 Scion TC 01 30' Sleekcraft HP500EFI ![]() Your Local Amsoil Dealer |
Holy bumpage, Batman! Why has a year and a half old meaningless thread been brought back to life?
Cuz I had a question...
You got to be kidding me ...
Audio Junky
and you were correct... bail commented that the dynamat was poorly done because it didn't reach the far sides (edges) of the sheet metal. In actuality those are the most rigid parts of a flat stretch of metal... it is the center that you have to worry about. The guy at sounddeadenershowdown (.com?) did a lot of testing and even has videos and has concluded that putting x amount of mat on the center 50% is much better than putting x amount of mat evenly spread over the same amount of metal... for example, you have 4 sq feet of flat metal surface, you also have 4sq ft of mat... you'd be better off covering 2sq ft of the metal, but doing two layers thick.
Si,,,, swidd.... yeah, you are right... covering all the metal with the mat is an aesthetics issue only. |
Audio Junky
oh yeah... and really.. the heatsinks on amps aren't meant to disappate heat... they are so poorly designed they shouldn't even be called heatsinks... they have a horrible surface area, therefore are poor at transfering the heat to the surrounding air regardless of what position they are in. I wouldn't be too concerned with position. Plus, to get any kind of cooling improvement you'd need to install a low noise fan, like a low output 120mm computer fan (and reduce the voltage to say 9v using a rheostat to help keep noise at a bare minimum).
