Old 09-07-2009, 01:45 AM   #1
tobymak21
Drives: 09 Yaris 5door
Looking for Upper Shock/Strut Mount??
Hey, I have couple question for ya and hope someone will lead me a hand.
currently, i have a 09 5 door yaris with stock everything~ i m planning on my suspension upgrade, i m looking to buy the tanabe df210 with the tokico blue shocks/strut.I do notwant to remove the springs off the oem shocks/strut because i want to be able to make quick changes if necessary from stock to aftermarket, but i would have to if i were to use the oem shock/strut mount for the new shocks so....
1) Where can i get replacement/oem/aftermarket strut mount?? and i am talking about the top "hat" of the suspension where u mount to the engine bay.
2) Does that mean i need 4 strut mount? 2 front, 2 rear?
Thanks in advance~
tobymak21 is offline   Reply With Quote
Old 09-07-2009, 02:24 AM   #2
Brian
Brian's Avatar
[QUOTE=tobymak21;380612]
QUOTE]
Junkyard or dealer
Old 09-07-2009, 04:37 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Thanks in advance~
I drempt of doing this until I priced out the various parts which are needed to complete the strut assembly (over and above the strut and spring). Not only do you need the upper strut mount but also the spring retainer plate. Much cheaper to buy/borrow a strut type spring compressor and spend 20 minutes per side to re-use the OEM parts.
As far as the rear goes, no strut assemblies there. Shocks are independant from the springs with a simple re & re process to change all.
TIP: go to Sparks website and locate the TRD springs. You'll find a PDF of the printed instructions provided. There you can see the steps and parts involved.
Old 09-08-2009, 01:47 PM   #4
tobymak21
OOOO.......thanks, by far this is the most helpful answer, i will look into it~ thz again!
Anyone w/ the sedan try ProClip's Center Mount Yet? Micko General Yaris / Vitz Discussion 2 07-14-2009 04:45 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
Camera mount in action m911gt Photo-Video-Media Gallery 43 02-04-2009 03:50 PM
ghetto camcorder mount acrbill DIY / Maintenance / Service 31 01-12-2009 11:37 PM
Where did you mount your capacitor? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 20 10-28-2008 11:22 PM
