![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
Trans slams at WOT
I have an odd problem with my Yaris. About 50% of the time, when I floor it, the trans will downshift, then it sounds like it hits a neutral condition, then slams back into gear, and will repeat this cycle until you let off the accelerator. Other than this, the car, motor, and trans all work as they normally should.
Is this a common issue on these? Anyone experience this, or hear of this happening, and any clue what the fix is? Drive by wire is a new animal to me. I am assuming it has something to do with the TPS, or whatever Toyota uses there. Any help is much appreciated! |
| The auto trans > manual trans conversion guide | ArmstrongRacing | Performance Modifications | 43 | 10-23-2022 04:33 PM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| Dropping the tans in a 2zr swapped Vios | tmontague | Performance Modifications | 2 | 04-29-2017 08:29 PM |
| Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-25-2009 12:08 AM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
