Old 05-05-2011, 06:07 PM   #1
lbagley9222
Drives: 07 yaris
Unhappy Left rear brake squeak
I need help figuring out why my left rear brake squeaks when I let my foot off the break pedal. I've got the wheel off and the brake cover. The pads look fine. Suggestions anyone?
lbagley9222 is offline   Reply With Quote
Old 05-05-2011, 09:23 PM   #2
swidd
Drives: Yaris HB
Put lithium grease between the side of the shoe and the rear. It squeals when they move metal against metal.
Old 05-05-2011, 09:46 PM   #3
rossman
Drives: 2006 YARIS RS
Yea that will do the trick, it happens to me once and a while. Just needs lubrication. Its where the pads touch the back plate...not sure the correct terms. Each pad makes contact with the back plate at 3 or 4 points lubricate them all to rid the squeeling noise.
rossman is offline   Reply With Quote
Old 05-06-2011, 11:05 AM   #4
rossman
See attached photo.
Old 06-08-2011, 12:29 AM   #5
Former_Neon
Drives: 1997 Yaris LE
This has been driving me nuts for two years. The dealership always says I need to clean the brakes (but they told me this a month after I had them cleaned -- when the squeal began again). I can't be getting them cleaned every month, so maybe I'll try the greasing trick.
Former_Neon is offline   Reply With Quote
Old 06-08-2011, 01:06 AM   #6
matthewai
matthewai's Avatar
Drives: it is kinda stock
quick question about the brakes when do the stock pads need to be changed ? how many miles approx
Old 06-08-2011, 03:00 AM   #7
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
i have the same problem... im going to try to lubricate them and see what happens.. imma try this either today or tomorrow..
Old 06-09-2011, 09:17 AM   #8
swidd
Drives: Yaris HB
I looked at/intended to replace my pads at ~86,000. They still had over 50% life left (replaced front anyway for the lulz). Holding the new next to the old showed no difference on shoes, and only slight wear on pads. Half the life of my Yaris is in hilly areas, and I thought I was running the brakes hard.
You will need to adjust the rear shoe "star wheel" to stiffen the brake and parking brake over time.
Old 06-10-2011, 09:48 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
common yaris issue. they ALL squeak sometimes. grease the backing plate
thepartsmancometh is offline   Reply With Quote
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
