Old 12-14-2009, 07:34 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
change coolant
is there a how to on swapping coolant..? how much does it take to fill?
I got 2 gallons today..
Also need a how to on changing the serpentine belt...got one for 12$
today. Dealer wanted 70 to do it. Idiots.
1.5 Liter hatchback with AC
yaris9876 is offline   Reply With Quote
Old 12-14-2009, 08:08 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
DIY coolant service.
Tools needed: Container to catch old coolant
Supplies: Genuine toyota antifreeze, distilled water.
Step 1 remove radiator cap.
Step 2 remove drain valve on bottom of radiator by twisting it counter clockwise and drain coolant.
Step 3 tighten drain valve by turning clockwise till snug.
Step 4 fill radiator back with a mixture of coolant/water 50/50.
Step 5 run vehicle with radiator cap off till air burps from system and cooling fan cycles.
Step 6 put back on radiator cap.
Step 7 wash hands.
Old 12-15-2009, 09:56 PM   #3
ddongbap
Step 7 wash hands.
So don't forget to drain it in the storm drain righte?
Old 12-15-2009, 06:31 PM   #4
SilverGlow
Drives: 2007 Yaris Hatchback
How many miles does your Yaris have? I think the replacement of coolant is not required until 100,000 or more miles....
SilverGlow is offline   Reply With Quote
Old 12-15-2009, 09:21 PM   #5
yaris9876
170K
Old 03-31-2010, 11:52 AM   #6
swidd
Drives: Yaris HB
Is there any horrible consequences to running 100% coolant fluid, and not mix it with distilled water?
Old 03-31-2010, 02:44 PM   #7
RedRide
RedRide's Avatar
Yes there are. For one thing, antifreeze will leak in places where plain water wont. The higher the concentration of antifreez, the more likely you could have a leak somwhere.
BTW, I don't know of any dealer or independant garage that actally uses distilled water when replacing antifreez so, the earth will still be in it's orbit if you use clean, plain tap water.
Old 04-01-2010, 09:15 AM   #8
1stToyota
1stToyota's Avatar
[raises hand]
Uses distilled water, even Culligan's filtered water at times, but getting away from mixing full strength antifreeze and using only premixed now because it's easier.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-01-2010, 02:39 PM   #9
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
There is no horrible consequence for not adding distilled water to 50% of mix. Water is a better transfer medium for heat energy. Anti-freeze is exactly that, anti-freeze. In winter water will freeze at 32 deg F, anti-freeze prevents freezing well below 0 deg. Running only anti-freeze will reduce the efficiency of your cooling system, especially during summer, because of a lower boiling point.
Old 03-31-2010, 01:20 PM   #10
Rick
Drives: '08 Yaris LB 5M
Yes, most would consider the consequences horrible. You can buy some brands of coolant that are premixed if that helps any.
Rick is offline   Reply With Quote
Old 04-01-2010, 04:10 PM   #11
Rick
Pure ethylene glycol (100% coolant fluid) will freeze at 10F. It will boil at 384F. It will also reduce the cooling capacity of your cooling system by about 20% compared to a 50% blend with water.
The corrosive chlorine blended into most tap water is the biggest reason they say not to use tap water.
http://www.engineeringtoolbox.com/et...col-d_146.html
http://en.wikipedia.org/wiki/Ethylene_glycol
Old 04-01-2010, 07:21 PM   #12
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Having owned my share of crappy old used cars, I never put anything other than distilled water (and anti-freeze) in my car. It's like 99 cents per gallon, you'll need maybe a gallon. Worth it.
The reasons for not using tap water include chemicals, but for me, it's more a matter of the minerals in your tap water. You don't need all of that sediment and potential lime calcification in your cooling system.
As for the belt and the dealer's $70 replacement of it vs. a $12 parts store belt... YMMV, but I've had several cars (Saturn, Miata and MX-6 that I can think of) that suffered from terminal belt squeal on cold starts with cheap parts store belts. A good OE belt might cost 3x as much, but it's a much higher quality belt and eliminates such problems. Your Toyota belt lasted you 170,000 miles...
Old 04-11-2010, 03:40 PM   #13
total
Drives: toyota vitz
hi my coolant indicator stays on but green ,do you think that there is something wrong please help
total is offline   Reply With Quote
Old 04-12-2010, 08:33 PM   #14
swidd
Drives: Yaris HB
At $22.70 per gallon, I only bought one gallon! The manual says it should take a little more than one gallon.
How can I drain it in a way that leaves like 1/8 of the fluid in there? Would it be okay to only open the drain valve on the bottom of the radiator, run it for a few seconds to let the water pump squeeze fluid out of the hoses, and then fill it up and call it a day? I don't think it can be necessary to do a flush or anything like that... What do you guys think?
Old 04-13-2010, 03:08 PM   #15
kou
Drives: 08 lb
Your thermostat could be stuck open and not letting your car get warm or it could just be the coolant temp sensor.The factory service manual should have ways to check them,they are cheap parts and easy to replace.
Old 04-13-2010, 03:11 PM   #16
kou
Drives: 08 lb
They make a Toyota 50/50 coolant mix.
Old 04-13-2010, 01:10 AM   #17
Loren
What?
Loren's Avatar
That's one of those things that if I'm going to bother doing it, I'm going to do it thoroughly.
I'd pop the radiator drain and let it drain. Search the manual and see if there's a drain plug you can remove on the engine block. If not, you're probably not going to get more than maybe 2/3 of the coolant out via the radiator, anyway.
After draining, put the plug back in and fill with distilled water. Go for a drive, get the car fully warmed up to be sure the thermostat is open and you've flowed that water throughout the whole system and at least diluted the remaining old coolant.
Let the car cool a little so you don't scald yourself, then drain again. If you're really anal, refill with water and repeat the above again. By the time you're done doing it a second time, you should have most of the old coolant out of the system. You'll also have a pretty good idea of how much coolant you're draining out of the radiator vs. the full capacity of the system.
After your final drain, put the plug back in and fill with your new coolant. If that's not enough, you don't need to buy another gallon, just top it off with distilled water.
FWIW, most modern coolants are good for at least 5 years regardless of mileage. Your 2007 is probably good for another year or so on the factory coolant.
Old 04-13-2010, 10:59 AM   #18
bronsin
bronsin's Avatar
On my ECHO draining the coolant with just the radiator drain got all of it out. I measured what came out and compared it with the published figures.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 07:55 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 03:20 PM
Change Engine Coolant curtqn DIY / Maintenance / Service 34 06-25-2009 12:25 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
