Old 09-04-2009, 12:52 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
drop/rub limits?
I knwo this has been discussed a bunch before, but I still cant' seem to get a definitive answer, if there is such a thing, so I'm going to go all "noob" on y'all.
Will a 215/40/17, mounted on a 17x7 +42mm, rub with the NF210's, in typical daily driving? I helped a friend install some used TRD's from a Scion (supposedly the same part# as the Yaris) on his yaris with similar size tires/rims, and his drop was almost 2", and they rubbed pretty easily on cornering and dips. OEM struts, cut bumpstops. I don't want this, but do want a mild (1") drop to close the wheel gap.
I understand that some rubbing on very hard cornering and large dips is almost unavoidable on a dropped vehicle, but I really could only tolerate a minimal amount. Is this realistic, or am I going to need a different tire size to get what I want?
Old 09-04-2009, 12:55 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
1. the springs are all wrong, and dangerous
2. with a proper alignment you won't rub with that setup
Originally Posted by xnamerxx
you nailed it sir.
Old 09-04-2009, 12:58 PM   #3
ozmdd
ozmdd's Avatar
Cool. Could you expand on the "wrong and dangerous" part? I'd like to pass this on to my buddy.
Old 09-04-2009, 01:02 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
front: the top perches are completely different
rear: the lower perches are completely different.
the fact that you even got the springs to stay in at all is a mystery to me.
you nailed it sir.
Old 09-04-2009, 02:05 PM   #5
ozmdd
ozmdd's Avatar
They fit the perches fine, so there must be more than one Scion spring set. Either that, or they were never Scion springs to begin with.
Old 09-04-2009, 03:09 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
possibly a scion xd
you nailed it sir.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 03:57 PM
The limits of negotiating 2+2 New YARIS Purchase Forum 12 08-06-2009 12:34 AM
