Old 09-15-2009, 08:42 PM   #1
The Shape
Drives: 2007 Yaris Sedan
Oil Plug do you prefer Ratchet or Box end wrench?
I am doing all the service on our Yaris these days to save cash. I am just paranoid about stripping the oil plug. Which do you think is easier to control and less likely to strip a ratchet or box end?
The Shape is offline   Reply With Quote
Old 09-15-2009, 09:19 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
hopefully it's not so tight that you need anything more than a combination wrench to take it off. either/or will work. even a 9/16"
Originally Posted by xnamerxx
you nailed it sir.
Old 09-15-2009, 09:25 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I use a ratchet to get it started, then a box wrench so I dont soak my arm in oil
Old 09-15-2009, 09:46 PM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
When i do my own oil I prefer a ratchet but lately i am curious about the Fumoto Valve system of changing oil.
http://www.fumoto.com.au/
Old 09-15-2009, 09:48 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
that's really bulky and oddly valved.
there are better options out there. brb i'll find one
edit: http://horsepowerperformance.com/i-1...ly-torque.html
Aeroquip is good stuff.
you nailed it sir.
Old 09-15-2009, 10:00 PM   #6
The Shape
The Fumoto wouldn't be that bad on the Yaris considering where the dran plus is on the side of the pan, but I would hate to try it on my Tacoma that sticks straight down. The Aeroquip stuff looks nice
Old 09-15-2009, 11:25 PM   #7
The Shape
Ehhh I think I may just go back to letting the dealer do the service. I am getting so old and Lazy LOL
Old 09-16-2009, 06:13 AM   #8
jambo101
jambo101's Avatar
Last couple of years i've been getting my mechanic to change the oil.he charges $60 considering the synthetic oil up here is close to $40 and a dealer filter is $10 its worth the extra $10,especially in winter.
Old 09-16-2009, 09:10 AM   #9
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Get a torque wrench and a socket. A decent beam-type wrench will run you about $20, and you'll never have to worry about stripping out the drain plug again.
bearda is offline   Reply With Quote
Old 09-16-2009, 09:15 AM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
the amount of torque required to strip those M14 (or M12) threads would be in the neighborhood of 200lb/ft. i highly doubt that a person could exert that kind of force lying down under their car with a box end wrench.
torque wrench is overkill, just get the plug "tight"
you nailed it sir.
Old 09-16-2009, 09:22 AM   #11
The Shape
It cost me about 45 bucks at the dealer for an oil change and tire rotation and they fill up my washer fluid. Combined with the fact I don't have to drag out my drain pan, wrench, ramps ect. it is sounding like a better and better deal.
Old 09-16-2009, 09:38 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
keep in mind that they're putting recycled oil in your car. your $45 goes toward labor mostly.
you nailed it sir.
Old 09-16-2009, 11:55 AM   #13
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Fumoto
I've had these on two previous vehicles and love them. Very user friendly and make changing oil even easier and cleaner. I am hesitant to put one on my Yaris though due to relatively low ground clearance and road debris concerns.
The Aeroquip that Tamago posted though looks like the ticket for a Yaris-I just might have to order one of those.
Tamago your commission check is in the mail, I'm sure!
R2
-The Fitful One
Old 09-16-2009, 12:16 PM   #14
The Shape
Toyota Oil is recycled????
Old 09-16-2009, 12:40 PM   #15
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Oh, I forgot to mention that for the first removal of the drain plug I recommend you use a 6 pt socket. Mine was really anchored in there (the filter was also ridiculously tight). After that if you don't crank on it putting it back in a box end would be fine IMO.
R2
-The Fitful One
Old 09-16-2009, 12:40 PM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
dealers buy oil in bulk, from their local oil distributor. it is usually recycled. if you personally see the tech open 4 bottles of oil and put them in your car, then i am wrong. but if they use an oil delivery gun it's most likely recycled oil.
you nailed it sir.
Old 09-16-2009, 12:54 PM   #17
The Shape
Oh, yeah I took my Tacoma in for service earlier today actually. I watched the tech walk to the parts counter and the guy give him a Toyota Filter and Toyota brand oil.
Old 09-16-2009, 01:44 PM   #18
06silveryaris
Drives: 2006 yaris
you can get 5 qts dino and a decent filter at any chain like pepboys
for $15
06silveryaris is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
