Old 08-15-2006, 01:15 AM   #1
SEaton
SEaton's Avatar
GROUNDING KIT DIY?
Can anyone post pics of an installed grounding kit? or a DIY
2007 Liftback in 4-5 weeks!
SEaton is offline   Reply With Quote
Old 08-15-2006, 02:26 AM   #2
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
Basically one head (alternator), one Block, one Ground...(sometimes one trans)...will try to post some pics tmr...
Linkseal is offline   Reply With Quote
Old 08-15-2006, 11:40 AM   #3
Linkseal
Drives: DBA-NCP91
Here are some pics of my Apexi grounding kits installation...
Connect to the battery and also connect within the Red Circle on the pics...
Member Jbann also has one connect to the Transmission...I think that is also a good location to connect...I might do it also...
Link
Old 08-15-2006, 01:07 PM   #4
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Guys what have you gained with that kit?How much did it cost?
Do you know any place from which to buy it in Greece?
Old 08-15-2006, 03:54 PM   #5
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
I think a "grounding kit" is a REAL JOKE!!!
OK... if you absolutely want to spend money to ground your car... just buy some feets of "no-name-brand" 8 GA power wire, some 8GA terminals (around 5¢ ea), plug it everywhere you want, then correct it on your batterie terminal bolts (use a longer bolt if there's not enough place on stock bolt) and do you own grounding kit for less than 15$!!
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 08-15-2006, 04:28 PM   #6
Linkseal
Drives: DBA-NCP91
Well...Grounding Kit is nothing special to use but better than none ...
Grounding Kits to N/A car might not have much improvement, but you can feel the difference for Turbo cars, especially Subaru or Porsche, which are placing flat 4 boxer or 6 boxer engines. For my Subaru STI, Apexi grouding kits help the car gains around 7whp on dyno (no kiddin)...and the rusts on the surface of bolts and turbo are less than others drving aound the same neighborhood....
Another reason for me to install it because this Apexi grounding kit also includes battery stablizer...used to be varying between 14.3 to 12.8 Volt, after installation the range of variation is reducing to inbetween 14.1 to 13.7 volt...basically make the electronic more stable while you open the AC , rear deforst, and listen to ur sub at the same time...
If you just want to ground your car, you can easily source some cheap materials to DIY...here is an example of my DIY grounding wires taken out from my used Audi S4..
Old 08-15-2006, 05:59 PM   #7
SEaton
SEaton's Avatar
cool thanks guys, think a DIY ground would be worth it on the Yaris
Old 08-15-2006, 06:00 PM   #8
SEaton
SEaton's Avatar
US Yaris
Old 08-15-2006, 06:53 PM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
...YES.
Follow the above pics, for locations.. you may add more if needed. Basically where I grounded all mine as well.
Old 08-16-2006, 12:22 AM   #10
SEaton
SEaton's Avatar
did you notice improvements chris?
Old 08-16-2006, 08:16 AM   #11
Chris07LB
Chris07LB's Avatar
Actually yes. If you read Paul's post one or two up from mine, he hit's the nail on the head!
I paid nothing for mine, as I had lots of brand new audio terminals and amp wire sitting around.
As for a DIY, go over to ScionLife.com, and do a search for Grounding Kit DiY. There was a very good how to, posted on an xB.
Old 08-16-2006, 01:02 AM   #12
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Yes.. paying $100+ for a grounding kit is rediculous, the only thing different between these expensive "magic boxes" and a DIY kit made of some lengths of large gauge wire and quality connections is maybe some noise filters and little things of that sort, the difference is negligable. There is, however, an improvement with any grounding kit, including the DIY kit... you may notice improved throttle response and smoother idle, to name a few benefits. I wouldn't recommend paying for one of those brand name boxes, make your own, save a few dollars, and reap the same benefits.
paultyler_82 is offline   Reply With Quote
Old 08-16-2006, 03:58 AM   #13
Katana
Katana's Avatar
Guys can someone explain to all of us how can we mace a ''home made'' grounding kit?What exactly should I buy and from where?
Old 08-16-2006, 11:19 AM   #14
Katana
Katana's Avatar
To save some time from all of you, there is the Grounding Kit DIY.
http://www.scionlife.com/forums/view...ight=grounding
PS, what does DIY mean???
Old 08-16-2006, 11:44 AM   #15
Linkseal
Drives: DBA-NCP91
DIY = Do It Yourself...
Old 08-16-2006, 01:48 PM   #16
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
where has the spirit of '77 gone?
argylesocks is offline   Reply With Quote
Old 08-16-2006, 02:13 PM   #17
Katana
Katana's Avatar
Guys where can I get these wires described in the DIY?And these connectors?
In an automotive store maybe???
@linkseal tnx for the info on DIY.
Old 08-16-2006, 07:49 PM   #18
johnnyfive
johnnyfive's Avatar
any electronics store will have them, or a car audio shop :)
johnnyfive is offline   Reply With Quote
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Radio Install Harness and Kit redbluff In Car Entertainment + Electronics (audio / video / alarm) 16 08-06-2009 02:40 AM
Trim/Dash Kit (for single DIN headunit) for Yaris yet? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 46 09-01-2006 07:30 AM
Just Finished Grounding KIt YES and YEs jbann Performance Modifications 14 08-16-2006 12:39 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
