Old 11-02-2008, 11:02 AM   #1
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
My Grill Block
Check it out guys... Whatcha think should I do the bottom aswell?
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
Old 11-02-2008, 11:22 AM   #2
better than some I've seen, nice job
Old 11-02-2008, 11:31 AM   #3
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Nice!...I just went with the cheap and easy and used black duct tape. Of course, the sedan's top opening isn't as large as the hatch's so it was easier to just use the tape.
Old 11-02-2008, 11:36 AM   #4
CKaelin
CKaelin's Avatar
Materials I used were as follows. This floor matt type thing that is foam like and plastic zip ties.. Had both at work. Free. So should I do the bottom opening aswell? I was thinking I'll wait till it gets really cold. See how it goes with this setup for now.
Old 11-02-2008, 12:51 PM   #5
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
I wouldn't do the bottom unless you've got a scangauge so you can keep an eye on your engine temps. Wouldn't want to damage the car
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 11-02-2008, 05:05 PM   #6
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
+1, are you running this currently? Keep an extra close eye on your temp.
Old 11-03-2008, 09:12 AM   #7
CKaelin
CKaelin's Avatar
I am using it currently. Just made it yesterday. It's been getting cold!
Old 11-06-2008, 09:08 PM   #8
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
i drove my yaris all winter last year with no block and had no problems at all. keep in mind that im in north central wisconsin. it gets pretty cold here and had no problems with it at all.
smofskra is offline   Reply With Quote
Old 11-06-2008, 09:16 PM   #9
Sodium Duck
╚══════════RN
You shouldn't have any problems. The point of the grill block is to make the engine warm up faster and stay warmer. I'm sure BailOut can give you the numbers, but in theory it should help improve your fuel economy in the winter months.
Old 11-06-2008, 09:29 PM   #10
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
man if you would have found some way to tie it without the zips it would look pretty sick.
Thej3sta2 is offline   Reply With Quote
Old 11-10-2008, 09:27 AM   #11
YarisDude
Drives: Yaris Hatchback
Looks Real Nice!
Great job, looks very professional.
Someone mentioned in a previous post, to loose the zip-ties. I used Velcro to fasten my block. Makes it real easy to remove in the summer or on the rare hot winter days....push-on & rip-off!
YarisDude is offline   Reply With Quote
Old 11-11-2008, 09:37 AM   #12
Treyz
~ ambient one ~
Treyz's Avatar
Hmmm .. but doesn't it block a bit more airflow to your intake which you want?
It's understandable in terms of warming up the engine, but I'd personally take airflow over warming your engine up quicker. Lol what, can't get a remote start or start your car 10 min before leaving?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Last edited by Treyz; 11-11-2008 at 10:57 AM. Reason: spelling and punctuation fixes
Old 11-11-2008, 10:10 AM   #13
Sodium Duck
╚══════════RN
Starting your car 10 minutes early would waste gas. You should read, too. This isn't a performance mod obviously, however I doubt it would make any noticeable difference in power.
As I said before, the grill block helps the engine warm up faster, and stay warmer for longer after you turn the car off in case you will be starting it again shortly.
http://www.yarisworld.com/forums/showthread.php?t=8985
One of the main reasons that fuel efficiency drops in the cold months is because fuel doesn't burn as well in a cold environment. Your engine can't always keep itself warm, and when its temperature drops too low your ECU starts feeding even more fuel into it in order to force it to run at a higher RPM in an effort to generate more heat.
In order to stop this wasteful cycle many people block their engine grilles in the colder months in order to stop the flow of too-cold air into the engine area. My own rule of thumb is to block the upper grille when daytime temperatures are peaking at 65F, and also the lower grille when daytime temperatures are peaking at 55F. I also use an engine insulation blanket once daytime temperatures drop to 45, and I will post a DIY on that when that time comes.
Old 11-11-2008, 01:14 PM   #14
Sodium Duck
╚══════════RN
The Yaris consumes 0.2 GPH at an unencumbered idle. While that may not sound like much if you think about how much time you spend idling over the course of a full tank it becomes a significant factor in your overall mileage.
Another lovely BailOut quote. Yes, it does waste a lot.
Doing something like not idling for an excessive amount of time, or turning your car off at lights isn't ridiculous, it's really simple and easy to do.
Bassically, if you don't want to do it, then don't and stop complaining about it. Or search before you post, so you actually know what you're saying.
Old 11-11-2008, 01:53 PM   #15
06vitzRS
Drives: 06 Yaris HB
I'll be making a winter front this weekend. My car JUST hits operating temp (86) as i role into the parking lot at work. (25min drive.)
06vitzRS is offline   Reply With Quote
Old 11-11-2008, 02:55 PM   #16
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
hmm...might think about making one of these.
glad i read this, i was confused as to what the purpose of a grill block was. i thought it was for aerodynamics!
duh
stuffy is offline   Reply With Quote
Old 11-11-2008, 04:47 PM   #17
CKaelin
CKaelin's Avatar
Originally Posted by Jack Reacher View Post
How much gas are you really wasting? Seems like a waste of time to me. You already got a car that gets 40 or so mpg. If you want to save even more gas get a bicycle or a hybrid. There comes a point where things just become ridiculous and this is one of those times. This and turning your car off at lights.
This is a Fuel Economy Forum broseph..
Old 11-11-2008, 05:20 PM   #18
Sodium Duck
╚══════════RN
So this whole conversation got way off topic...
I think I'm going to make a grill block myself, too. Whoever was using the velcro to hold it on, how's that hold up? You think a couple feet of snow and some highway speeds will take it off?
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
Grille Thread.. Blenjar Cosmetic Modifications (Exterior/Interior) 40 11-14-2010 04:26 AM
New grille or not free297 Cosmetic Modifications (Exterior/Interior) 27 11-14-2010 04:21 AM
Need help, removing grill, adding new one drbilal DIY / Maintenance / Service 4 10-29-2008 10:11 PM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 07:52 PM
