03-18-2007, 12:55 PM | #1 |
Drives: 2007 Yaris LB Join Date: Mar 2007
Problems starting the engine
Hi,
I've had my Yaris for 6 days now, am happy with it, but I've been experiencing a problem when starting the engine. I try to start it and sometimes nothing happens. Just like when you don't have the clutch pedal depressed. It happened a few times already, so I'm starting to get worried. This morning it happened on the exit ramp off the highway. I was waiting for traffic to pass, it was a little steep, so I stalled the engine. It took me about 5 tries to re-start it. It's weird, it doesn't happen all the time, I keep trying a couple times and eventually it starts. Afterwards I went to get gas and after I filled it, it didn't start either the first 2 tries. Does anyone have any idea, did anyone experience this before? Thanks, Florin |
03-18-2007, 01:05 PM | #2 |
take it to the dealer, there's gotta be a bad electrical connection somewhere, most likely the clutch sensor or the starter system itself...
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson Bye bye 1NZ... |
03-18-2007, 02:34 PM | #3 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
yes, it definatly sounds like a electrical problem, i have experienced these these things in other cars, it can be something as simple as a bad ground on the starter or could be as bad as the PCM/ECU loosing communication with the engine.
It is still under warranty, so let the dealership figure it out.
03-18-2007, 06:29 PM | #4 |
Problem solved! I feel a little stupid, but I'm relieved, there was nothing wrong with my car, it was my foot :-) I experimented a bit and realized I wasn't depressing the clutch all the way. 5 mm made all the difference.
GO YARIS! |
03-18-2007, 10:13 PM | #5 |
der Zeck
Hey Thomas bring back memories of you and your Yaris for the first time starting at the dealership?
03-18-2007, 10:42 PM | #6 |
*whistles innocently*
03-21-2007, 05:44 PM | #7 |
At least your car is fine!
10-06-2009, 08:10 PM | #8 |
Drives: 2009 Toyota Yaris Join Date: Oct 2009
Man, did this thread save me a lot of headache! Same story. I've had my Yaris for about 2 months, and it's an awesome car! Yesterday, I went to start it, and nothing. All the instrument panel lights came on, but the starter and engine were silent. After a few attempts, it started just fine.
This morning, same thing. And after a few tries, it started. I got to work, and immediately called the dealership, scheduled a tow truck and cussed my new car! On a whim, I Googled "Toyota Yaris ignition problem" and this was the first thing that appeared. I went outside, put the clutch to the floor, HARD, and she started right up. I tried it several times with different amounts of pressure, and that 5mm of play really does make all the difference! The weird thing for me is, I haven't changed the way I drive that car since I bought it, so why now is it so sensitive? Is the clutch "adjusting"? Is my left hip crumbling? Thanks for the tip, y'all! |
10-06-2009, 09:00 PM | #9 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
On my 5 speed ECHO I had ice get in the clutch switch during the winter. Press down all the way on the clutch and...no start! I replaced the battery because it was 7 years old (stupid...there were bright ignition lights!) New battery...same results! In frustration I slammed down on the clutch and felt the ice crack and give about half an inch and it started. Something to think about when your manual equipped car wont start. If I had a manaul now I would short the two wires together on that freakin switch!
10-06-2009, 09:21 PM | #10 | |
For my remote starter, but same effect, lol, and it works |
10-07-2009, 08:48 AM | #11 | |
Drives: 09 3dr LB MT Join Date: Aug 2009
But now that I'm experienced (all of only 2 months to the day), I don't have this problem. (well, the starting at least... the stalling still happens on occassion when stopped going up a hill and I don't feel like redlining it to get it moving again......)
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!! |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 07:17 PM |
Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
service engine light @ 9000 mi? | dandj | DIY / Maintenance / Service | 21 | 01-03-2007 12:30 AM |
Advice on engine light/exhaust problems PLS... | DollaZo | DIY / Maintenance / Service | 13 | 12-29-2006 05:24 AM |
Noisy Engine | David81 | New YARIS Purchase Forum | 8 | 06-02-2006 12:15 PM |
