![]() ![]() ![]() Drives: jdm yaris sedan Join Date: Feb 2009
Greedy V-Manage comments about it
![]() The V-Manage, Variable Valve Timing Controller was designed by GReddy engineers to take advantage of some of the modern technology OE Manufactures* are now commonly incorporating into their latest engines. Based on the intuitive controls, datalogging and Maps of the e-manage Ultimate software, a tuner with a laptop computer, can now alter the factory’s ECU control of valve-timing at any RPM and load to optimize power output and fuel economy. However by purchasing GReddy's application specific V-manage Kits, you can simply "plug & play." V-manage Kits, include the V-manage, CD software, Plug-in Harness with adapter, and Pre-programmed MAP to optimise cam timing for increase horsepower, toque, and boost response. (* Mitsubishi MIVEC, Honda iVTEC, Nissan CVTC, Subaru AVCS, Toyota VVTi,VVTL-I, Dual VVTi)
vvti bregao! |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
se ve ready eso!!!
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
Sweet. I looked into this a while ago. Seen it on a local Honda and the software is easy to use and does make a difference.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
bout time. i have a $60 program for a laptop, a $20 cable to hook lappy to car, and a laptop that can change any variable controlled by the ECM for my camaro. lets see how this thing works. i hope it's what i'm thinking it might be
i'm interested....specially now that someone's coming out with some cams around here. maybe now we can get some seriously aggressive cams and very efficiently control them with this thingy. |
so can this really work with our computers?? and tune fuel and air mixtures while doing cam timing...like an apexi neo with a camcom
vvti bregao! |
It says it works with VVTI
wonder how much work it is to wire it though.
The honda ones are plug and play. I can't imagine that the Toyota ones wouldn't be the same.
1NZ-FE
this is just for vvti control or you can adjust AFR too? if it's both it's a sweet item!
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
![]() Drives: 2005 Scion xB Join Date: Nov 2008
So this appears to do the same thing as a power enterprise camcon?
IF so I've heard reports of decent gains. |
| Sales Feedback Thread | eTiMaGo | Items for Sale by private party | 188 | 05-04-2019 11:43 AM |
| E Manage Ultimate | cdydjded | Performance Modifications | 5 | 05-14-2009 02:37 PM |
