Old 06-12-2013, 04:19 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
removing wheel hub
rear hub 07 hatch
I beat on these rear hubs with a wood mallet for a long time and there was NO sign
of them coming off or even loosening. Do I need a special tool to get the hubs off???
Are the front ones the same also??
I meant the brake drum...not the inner hub...its the drum thats stuck.
yaris9876 is offline   Reply With Quote
Old 06-12-2013, 04:39 PM   #2
kou
Drives: 08 lb
If you are trying to take the drum off you will need 2 bolts that thread into the 2 holes on the front off the drum. Screw in the bolts evenly and they will push the drum off.
Old 06-12-2013, 04:49 PM   #3
kou
Drives: 08 lb
I think the bolt size you need is M8x1.25 but I am not positive.
Old 06-12-2013, 04:53 PM   #4
kou
Drives: 08 lb
crappy video but will give you an idea.
http://www.youtube.com/watch?v=JFLP18_fNBg
Old 06-12-2013, 11:15 PM   #5
yaris9876
I honestly dont rememeber seeing holes in the drum.....I guess I have to take off the wheels again??
I didnt see them.
Old 06-13-2013, 12:13 AM   #6
Here's a picture of the location of the threaded holes. Also, make sure the ebrake is off, or you will never get the drums off.
Old 06-14-2013, 12:00 AM   #7
yaris9876
that helps....
btw is there a good pictorial of doing the front wheel bearings, not a video,just a good tutorial from someone who has done it..??
Old 06-15-2013, 11:54 PM   #8
yaris9876
can you describe this clip process better or link to better pics??
http://www.popularmechanics.com/cars...enance/1782947
Old 06-18-2013, 08:28 PM   #9
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Originally Posted by yaris9876 View Post
that helps....
I have some pics from when I did it. I didn't get pics of every step, as I got frustrated not having the proper tools.
Question: are you going to buy a new wheel bearing / hub assembly, or just a wheel bearing? I've been told to do the hub assembly as a unit. I didn't have that much at the time I did it, so I only did the wheel bearing.
I will TRY and get something going tonight.
edit: yikes. removing the pics from my windows phone isn't as easy as it was with my iPhone. damn it.
Old 06-18-2013, 11:16 PM   #10
yaris9876
I am doing the whole hub///do you know the bolt torque on the hub bolts?? hope you get the pics up
it would help..
Old 06-19-2013, 01:50 PM   #11
justjesus
justjesus's Avatar
the hub isn't bolted to the spindle assembly. It's pressed on. For that part, I took it to a shop (Pep Boys). - If you're talking about the lugs, those too are pressed on (and should be part of the hub assembly you buy new)
I brought a blank CD to help me move the files off my phone and onto the internet. I'll be doing it little by little during the day
Old 06-19-2013, 06:03 PM   #12
yaris9876
the rear hub assembly is bolted on to the rear axle. There are 4 bolts and I am looking at them right now. Anyone know the torque..???
Old 06-19-2013, 07:03 PM   #13
justjesus
justjesus's Avatar
67 ft lbs for the four bolts
Old 06-19-2013, 08:50 PM   #14
racerb
Like others have said, buy the whole hub assembly, it's way easier unless you own or have access to a press. Here is an example of a new Yaris hub from Rock Auto, where I buy about 80% of my parts.....
http://www.rockauto.com/catalog/more...658&cc=1444575
This is what you end up with if you break them down yourself, hubs and bearing carriers just waiting for bearings and seals to be pressed back in.....
http://smg.photobucket.com/user/race...tml?sort=6&o=9
And this is what you'll need to make it all happen, but really there's more to it than that, this is just a simplified look at what's involved......
http://smg.photobucket.com/user/race...ml?sort=2&o=38
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 06-19-2013, 09:51 PM   #15
yaris9876
I got the whole assembly today... same as the pic but mine were Timken and look good. I dont have a torque wrench, is 67 pounds reachable with a regular open end wrench???
Old 06-22-2013, 01:09 PM   #16
yaris9876
can someone verify that the hub screw holes are M8 1.25 ????
Old 06-23-2013, 10:31 AM   #17
eddie054
Yes, did it yesterday and got them at Home Depot.
eddie054 is offline   Reply With Quote
Old 06-23-2013, 06:51 PM   #18
yaris9876
I got into it only to realize I didnt have a 14 mm.I was going to buy one and then I called a Les Schwab
and they said 90$ if I had the parts. So they did it . It took 3 hours by an experienced brake mechanic
who needed an air chisel to get the hubs off. I would not have gotten 1/4 of the way thru it.
Glad I hired someone else.
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 07:34 PM
FS: Sparco Steering Wheel Hub Adapter for Scion XA/XB &Toyota's jookybanana Items for Sale by private party 0 07-21-2011 06:38 PM
Steering wheel hub adapter spdfrk Cosmetic Modifications (Exterior/Interior) 7 02-18-2011 05:44 PM
anyone knows if wheel spacer can be placed behind the hub??? jackrabbit Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-02-2010 07:41 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
