Old 11-23-2009, 01:41 PM   #1
rossman
Drives: 2006 YARIS RS
Torque Wrench
Hi,
Does anyone actually use a torque wrench when swapping summer to winter rims?
In the past I have never used one and I dont think it did any damage to my rotors or pads. But now that I have a new car and a nice yaris I dont want to take the risk.
Suggestions???
Thanks
rossman is offline   Reply With Quote
Old 11-23-2009, 02:02 PM   #2
1stToyota
1stToyota's Avatar
Originally Posted by rossman View Post
Hi,
Suggestions???
Thanks
I always use a torque wrench on my lugs. I also use torque sticks. In general I use some kind of torque wrench on any nut/bolt I tighten.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-23-2009, 02:04 PM   #3
supmet
Drives: 2007 4 Door Yaris
^^ eh.. torquing is good, but your lugs will be fine as long as they are tight.
Old 11-23-2009, 02:04 PM   #4
Changing your wheels is not related to your brake system (rotors/pads).
I ALWAYS torque my lug nuts, but I think also take my wheels off more often than most do.
Old 11-23-2009, 02:09 PM   #5
i swapped wheels about a half dozen times this summer and never use my torque wrench anymore....though i used to use it all the time
now i just use a breaker bar w/ my socket to tq my lugs. a friend of mine from MO.com was surprised and disappointed that i didnt tq my wheels until he checked one of my wheels....was pretty much the right torque! ;)
i guess i just do it by feel now....
got some wheels overtorqued on the aveo by a local shop who obviously used an impact wrech....had to use a 4' long pipe on the end of my breaker bar to get them off!
Old 11-23-2009, 02:11 PM   #6
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
If you overtorque the lugs can't you warp the rotor? Kind of makes sense since you're increasing pressure on the rotor, especially if the torque is unbalanced from each lug.
bearda is offline   Reply With Quote
Old 11-23-2009, 02:22 PM   #7
Indianspringsaz
Drives: 07 Bitchin Blue HB
No
Indianspringsaz is offline   Reply With Quote
Old 11-23-2009, 02:36 PM   #8
supmet
Ya, I've seen/had 2 cross threaded lugs(the 4 foot pipe just snapped the lug ), and about 100 over tightened from tire shops, dealers, brake shops, quick lube places. I'd say most place just impact them on way to tight... discount tire is the only place I've seen torque them, and you still have to watch to make sure they pick up the torque wrench sitting 5 feet away
Its probably *best* for the car to torque them every time, but far from necessary
Old 11-23-2009, 05:41 PM   #9
nemelek
DWEED
nemelek's Avatar
I don't torque mine.
Old 11-23-2009, 05:53 PM   #10
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
As far as I know, the aluminum/alloy wheels are more sensitive and should be torqued correctly, to insure that you have the same pressure/tightness on each bolt. I never used a torque wrench before on all my previous stock steelies, but it's a different ball game now
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 11-23-2009, 06:32 PM   #11
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I always use a torque wrench. It makes removing them a lot easier when it's time to swap again.
Old 11-23-2009, 07:17 PM   #12
sex
sex's Avatar
Drives: 09 5DR
I use a 1/2" Husky Pro 50-250 ft-lbs. torque wrench during each rotation. I find a 13/16" fits better than a 21mm. Get the right tool and use it.
sex is offline   Reply With Quote
Old 11-23-2009, 10:56 PM   #13
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
I started using a torque wrench when the local tire shop stretched s few lugs putting on my snowies with an impact. Then they had the audacity to tell me that their impact was "torque controlled" and I was overtightening the new studs! Technicians they are not...
Old 11-23-2009, 11:25 PM   #14
put winters on both cars tonight....couldnt even find my breaker bar let alone the torque wrench.....giant ratchet ftw!
Old 11-24-2009, 12:33 AM   #15
YarisSedan
Drives: 08 Yaris Sedan
I always torque my wheels down. I think factory spec is 76 ft lbs
Old 11-24-2009, 09:10 AM   #16
MUSKOKA800
MUSKOKA800's Avatar
I always use my torque wrench for final tightening. Bought one, may as well use it. The extra couple of minutes isn't an issue. I also insist that tire shops do as well. If you've ever been on the roadside fighting to get lugs undone with only the OEM tools you'd understand why.
Old 11-24-2009, 11:57 AM   #17
robkay
Drives: Hatch
I try to torque everything to proper specs. Do you homework, though, as torque wrenches come in various torque ranges and, in particular, quality.
I bought an S & K 74101 which, to me, was a good balance between price and quality, and also a good torque range for most apps I would be using it for. Here's a link (you might find it cheaper other places; I bought mine at tooltopia.com, but it doesn't look like they carry it at the moment):
http://www.amazon.com/SK-74104-10-fo.../dp/B00061SNHK
robkay is offline   Reply With Quote
Old 11-24-2009, 01:41 PM   #18
Roscoe
Drives: Sporty
Location: " When we do right no one remembers, when we do wrong on one forgets. "
Roscoe is offline   Reply With Quote
Oil Filter Wrench blacksan DIY / Maintenance / Service 43 12-09-2010 08:11 PM
My review of the nitto torque dampner YarisSedan Performance Modifications 10 08-28-2009 07:13 PM
WTB RED Torque Dampner YarisSedan Willing to Buy by private party 4 03-31-2009 01:44 AM
Does anyone have a nitto torque dampner in grey? YarisSedan Performance Modifications 3 02-27-2009 12:43 AM
impact wrench question toad DIY / Maintenance / Service 4 12-11-2008 12:21 AM
