![]() Drives: 2003 Yaris Join Date: Oct 2009
Yaris engine durability??
I m curious How many kms or miles can a Yaris engine resist??
over 9000
Audio Junky
there's at least one driver in the US with over 350k... I think there is another driver over 300k too. Those people have been delivery drivers tho who do hundreds of miles a day mostly on highways.
Regular driving I would expect an engine to last at least 200k with regular preventive maintenance (oil changes, air filters, and swaping other fluids when needed) I'm currently at 38k... no problems with my engine. |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
I am at 145,000km with no problems. Other than my car being accident prone!
Reluctantly Crouched...
This engine design has been around for a while prior to the Yaris, and it seems to be a typical Toyota motor. (I.E. Reliable and very durable)
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I think most Yaris' can make it off the lot. After that it's a crap shoot.
![]() Drives: 2007 yaris Join Date: Nov 2008
I have 2 echos which is the same motor as yaris. My 2001 has over 150,000 miles and no problems at all. Probably will have to adjust valves and replace timing chain by 200,000 miles. I use synthetic Mobil 1 oil since it was new.
Half a Bubble Off Plumb
Mine's made it nearly 7000 miles!
The 1NZ-FE is the same engine that was used in the Echo and in early Scions. It is basically the same as the engine in the first two generations of the Prius. (The 1NZ-FXE Prius engine came first, and the Echo/Scion/Yaris engine was a minor modification of it.) It has a good service record. |
Hakan didn't say where he lives. The 1NZ-FE of which I spoke is the only engine used in the United States for the Echo, early Scions, and Yarises. The 1.3L 2NZ-FE is basically the same engine with a little shorter piston stroke. The 1L 1SZ engine is built by Daihatsu. The 1.4 liter turbo diesel's another option. None of those are available in the U.S. If the diesel were, I'd've bought one.
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
The member trini_per4mance has over 380,000 miles on his '07 with no problems.
This little 4-banger is bullet proof. |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
Really! Do you have any other information about it? How interesting.
You can rest assured that the ECHO/Yaris engine is one of if not the finest engine EVER made for a motor vehicle. Its durable, powerfull, and gives outstanding FE. |
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
Can anyone name a toyota motor that isnt
With proper maintenance 300,000kms is easily obtainable with no major problems.I'd be more concerned about the body rusting before the engine gives you any problems,If you are planning to drive the car for 10+ years a yearly oil spraying will be money well spent in preservation of the body.
http://www.krown.com/#process/ |
Toyota owns a big stake in Daihatsu. They've done a number of joint ventures.
![]() Drives: Corolla Join Date: Sep 2009
There is a guy on you tube with over 300k in his. Just do a search for 300000 mile toyota on you tube and you'll find it. He is a medical courier, the only major thing he replaced besides oil changes, batteries, and brakes was his alternator.
2003 Echo - Auto Trans - 93,000 mi. |
He's right here on this board, and has a long thread about it right here in this forum.
Here is the link to the 300k plus yaris. And I was wrong about his brakes, he still has the originals.
http://www.yarisworld.com/forums/sho...highlight=300k
| Engine beautification for those show car yaris out there | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 7 | 09-30-2009 11:18 PM |
| Has anyone put in a different engine for the Yaris? | marlondog | Performance Modifications | 7 | 04-14-2009 06:03 PM |
| Is your Yaris 1.5 Engine noisy? | Yawesh | General Yaris / Vitz Discussion | 49 | 04-13-2009 12:25 PM |
