![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
What about this Oil Catch Can?
http://cgi.ebay.co.uk/Viper-Performa...item53ddc7404e
Do you guys suggest me to buy this for my turbo 1NZ? |
Learn to Relax
In any case, they look nice.
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
I wouldn't consider buying a catch can unless you can see what is inside it and how it is baffled etc to help the oil vapour condense. Alot that I have seen have nothing inside at all. Cheap but far from ideal.
or you could buy the new MicroImage Branded ones , they are baffled
with S/S Wool from memmory |
Do you know about a particular brand or one you can suggest that suits me best?
How can I know if the catch can I am seeing is good for my engine?
What Dimensions? LxBxH? Is there a rule to calculate with? What about fittings dimensions? In, Out & Top? |
^ I can't find them either, must be a hoax. Just kidding, we need to post them up.
Parmas $100 USD is a little steep.
Ray has some for me to post up and I am just getting in some very nice Simotas that will be less expensive than the one you found there.
#11 | |
![]() And also becuase they are on my Work Bench. |
#12 | |
My thoughts on size: Street car running up to 15 psi - 0.5 to 1 litre in volume. Street car running over 15 psi - minimum 1 litre in volume. Race car - 2 litres minimum. |
#13 | ||
Are you sure on that 2litres? We are still talking about a yaris right ? I think one litre is enough for a weekend 16psi drag race car right? Quote:
Nope, serious. A race (circuit) car (Yaris or otherwise) is probably on boost for at least 50% of the time, compared to a street car which would be lucky to be on boost for 5% of the time. If you are just doing drags, then 1 litre would be heaps.
Do you even have blowby problems in your car or is the catch can just for looks? Last edited by rob323; 11-11-2009 at 05:37 PM. Reason: DIdn't read the above post fully. |
What do you mean by "blowby"?
Presently the 2 tubes are just disconnected from the top cover. When I check the enginebay I can see some fumes coming from them also on hot idling especially. |
I have nothing coming from those open holes, so I didn't put one in. When I go for road racing, probably will at that point.
Learn to Relax
On the compression stroke, some of the compressed air/fuel mixture escapes pass the piston rings to the crankcase. That's called "blowby." The escaping gas (blowby) is forced up the oil drain channels in the block and forces oil and gas (blowby) out of the PCV, which is what the oil can is for. The oil can captures the oil and allows the gas (blowby) to go to the intake manifold.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 08:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Oil catch tank question | window_lee | General Yaris / Vitz Discussion | 1 | 07-14-2009 09:04 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 02:55 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
