Old 02-08-2010, 11:59 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Changed my oil but only used 3 bottles ...
weird thing was me changing my oil last weekend.. drain it for about 10 minutes..then only used 3 bottles and im already in between lines on that dip stick..i also let it sit on flat surface for 2 hours and measured it again im still between lines..each of them amsoil bottle is about 946 ml.. not even a liter.. which mean that im getting i free oil change on my case of motor oil...sweet!
Old 02-08-2010, 12:06 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Only takes about 3.5 quarts. Don't panic, just put in what you need to get the dipstick to read full.
Old 02-08-2010, 12:09 PM   #3
Full oil change with new filter = 3.7 litres.
Difference between Low level and Full level on dipstick = 1.5 litres.
3 bottles = ~ halfway between low and full.
I'd top it up, not try to cheap out.
Old 02-08-2010, 12:57 PM   #4
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
I've changed the oil on this car 7 times now and mine always takes 3.5 qts. dead on to read perfectly full with a filter change. Yes, put the other .5 qt in and save the remainder for the next change.
UTVitz is offline   Reply With Quote
Old 02-08-2010, 01:32 PM   #5
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
thats what i have been doing, i basically save all my .5 qt of oil left over for basically a free oil change just buy a new filter
Aothachos is offline   Reply With Quote
Old 02-08-2010, 03:26 PM   #6
DARK AGE 53
Drives: 2009 Yaris Onyx
my 09 owners manual reads, 3.9 qt w/filter change and 3.6 qt without filter change.
DARK AGE 53 is offline   Reply With Quote
Old 02-08-2010, 03:49 PM   #7
Loren
What?
Loren's Avatar
Be that as it may... with a genuine Toyota filter... my experience has been that it takes somewhere between 3.5 and 3.75 quarts. There will always be a little oil left in the engine somewhere after you drain it.
Old 02-08-2010, 04:31 PM   #8
Hershey
new TOYO oil filter usually soaks up about 4 ounces of new oil . Then pour 3 qts. and 14 ounces into motor . I'll pour about 8 ounes of new oil in beginning of oil change to flush some used oil out that's left in pan then put drain plug back in when there's a slow drip of oil (some patience needed ) . In the end it usually reads at or a tad above FULL mark .
Old 02-08-2010, 04:35 PM   #9
marcus
toyota
marcus's Avatar
i always thought that its better to keep it in between rather than full.. but then again i could be wrong..
Old 02-08-2010, 06:28 PM   #10
Loren
What?
Loren's Avatar
For typical driving, being half a quart low isn't going to hurt anything, but there's nothing "better" about it. Bad habit to be in, really. If you're going to keep your car for many years, it will eventually start burning or leaking some oil. If you start off half a quart low, that's a half a quart less reserve capacity.
(my first car burned a quart of oil ever 200 miles, I learned to make sure the oil was FULL every time I checked it!)
Old 02-08-2010, 06:47 PM   #11
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
On a similar topic - do any of you fill the filter before putting it on? I've read that it isn't necessary, but it's an old habit so I'm just curious.
Old 02-08-2010, 08:30 PM   #12
DARK AGE 53
I've done that on every car I've owned.
Old 02-08-2010, 08:45 PM   #13
UTVitz
UTVitz's Avatar
I don't bother to fill the filter-seems to only make the job more messy and my oil light goes out in a second anyway upon start up. I've read everything from pull the fuel relay and crank for so many seconds to filling the filter and then screwing it on. However, not all cars have a vertically mounted oil filter so that's out on a side mounted one. They don't do it if you have someone else change it so I'd don't give it much thought. It definitely does not hurt, I'm just not sure how much it helps considering the hassle and possible mess it could lead up to.
Old 02-09-2010, 12:14 AM   #14
Hershey
yup , as stated . TOYO oil filter takes about 4 ounces of oil .
Old 02-09-2010, 12:16 AM   #15
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
same here, I only use 3 quarts of penzoil platinum.
Red Horse is offline   Reply With Quote
Old 02-09-2010, 03:40 AM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
About filling the filter - I don't fill it up the whole filter, I just fill it enough to "wet" the new,dry filter. I think priming the filter with new before installing is always a good thing.
3.5 quarts was about right for me, too.
Old 02-09-2010, 11:20 AM   #17
marcus
toyota
marcus's Avatar
great to know guys..i never thought of filling the oil filter though i figured once you start the car itll end up there asap..
Old 02-09-2010, 11:30 AM   #18
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I don't pre-fill the filter. I put in between 3.6 and 3.9 quarts. As long as it's reading full you'll be fine.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 02:55 PM
Got the oil changed Tuesday and today the "MAINT REQD" light came on.. firebird1999us DIY / Maintenance / Service 10 04-02-2009 09:24 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
